Help rough idle!!!!!!!!!!
Old Oct 18, 2002 | 03:51 PM
Canuck's Avatar
Help.!!
I just installed an extrude honed intake manifold and I have a rough idle. It fluctuates over about 1-200 rpm on the tack and outside the car it sounds like an old V8. Anyone have any suggestions on how to fix it?
Old Oct 18, 2002 | 07:34 PM
Canuck's Avatar
Re: Help rough idle!!!!!!!!!!
Originally posted by Canuck
Help.!!
Update. The engine does not smell of gas so I think the manifold is on fine. I breilfly ran my hand trhough the engine and I couldn't find any vacume leaks. Also the exhaust smells really rich.
Old Oct 19, 2002 | 10:19 AM
Canuck's Avatar
Anybody?
Old Oct 19, 2002 | 02:44 PM
Canuck's Avatar
Update
*Update*
I retorque all of the manifold bolts and checked for vacume leaks some more. But still no solutions.
Please help
Old Oct 20, 2002 | 11:56 AM
Canuck's Avatar
Bump
Old Oct 20, 2002 | 12:05 PM
96BLUMAX's Avatar
Well have you tried raising the idle?
Also reset your ecu.
Old Oct 20, 2002 | 12:08 PM
XXXL Cracker's Avatar
Canuck
It sound slike you have a leak. Check the area of your EGR downtube, the gasket may be worn.
I had the same symptoms when I installed my Vi and it was a vacuum leak. You can also get a vacuum gauge and tes tthe vacuum of your manifold.
PM or email me if you have any other questions.
Dave
Old Oct 22, 2002 | 10:32 AM
Canuck's Avatar
I found the leak and fixed it. The idle is back to normal now. But I have a new problem. When I shut of the car there is a loud wistle from th engine bay like something is letting off pressure.
Any ideas?
Old Oct 22, 2002 | 10:47 AM
mayhem_J30's Avatar
if you mess with the idle, wouldn't the ECU just fight it and adjust until the appropriate engine speed is found?
Old Oct 22, 2002 | 11:26 AM
njmaxseltd's Avatar
Any ideas?
Thats the vaccume in your manifold depleting. Could just be from your throttle body butterfly (normal) or you still have a leak.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
