Help rough idle!!!!!!!!!!
Help.!!
I just installed an extrude honed intake manifold and I have a rough idle. It fluctuates over about 1-200 rpm on the tack and outside the car it sounds like an old V8. Anyone have any suggestions on how to fix it?
Re: Help rough idle!!!!!!!!!!
Originally posted by Canuck
Help.!!
Help.!!
Update. The engine does not smell of gas so I think the manifold is on fine. I breilfly ran my hand trhough the engine and I couldn't find any vacume leaks. Also the exhaust smells really rich.
Canuck
It sound slike you have a leak. Check the area of your EGR downtube, the gasket may be worn.
I had the same symptoms when I installed my Vi and it was a vacuum leak. You can also get a vacuum gauge and tes tthe vacuum of your manifold.
PM or email me if you have any other questions.
Dave
Dave
I found the leak and fixed it. The idle is back to normal now. But I have a new problem. When I shut of the car there is a loud wistle from th engine bay like something is letting off pressure.
Any ideas?
Any ideas?
litch
123
01-04-2024 07:01 PM
Unclejunebug
04-02-2016 05:42 AM
