Where to get the lower control arm bushing???
Old Oct 20, 2002 | 08:36 AM
dmbrazilian's Avatar
Hey guys I need help, as some of you know I got rid of my max about 6 months ago, but my mom still has one and I am needing to change the lower control arm bushing and am having a really hard time finding them without having to buy the whole thing. PLEASE HELP
David
Old Oct 20, 2002 | 11:52 AM
Nealoc187's Avatar
SLOW
I've got a set of aftermarket Energy Suspension polyurethane control arm bushings for sale. I'd like to get $40 for them. I paid $50 and they have been sitting in my closet for the last year.
Old Oct 20, 2002 | 01:35 PM
Really, are they the ones for front part of the control arm? I just have been hearing that I have to buy the whole control arm for the particular bushing...How can I get more information so that I know that we are talking about the same thing? Please help cause I have to try and get this done this week, cause I got her new tires cause the alignment was off because off that and I don't want the new tires getting messed up too.... Thanks
David
Old Oct 20, 2002 | 03:03 PM
xraytedrick's Avatar
David
i purchased the same set mentioned above. yes they are for the lower control arm and the kit will do both sides.
Old Oct 20, 2002 | 03:31 PM
Where did you get yours from?
Old Oct 20, 2002 | 03:54 PM
Here go to this link and tell me if this is what you have...
http://forums.maxima.org/newreply.php
http://www.courtesyparts.com/Merchant2/merchant.mv?
Old Oct 20, 2002 | 03:58 PM
njmaxseltd's Avatar
I wouldn't get your mom the Energy Bushings. There very hard and she's going to feel & hear every bump in the road. I'm not so certain thats the kind of ride mom would like. Keep that in mind.
I'm sure you can order just the bushings from Nissan. I can't see why not? Special order I'm sure...
Old Oct 20, 2002 | 04:17 PM
I apreciate that man, but I have been researching all weekend long and can't seem to find them. I will probably go over to courtsy in the morning and check again.
David
Old Oct 20, 2002 | 04:28 PM
yes i got them from courtesy
i just got them and havent put them on yet
Old Oct 20, 2002 | 06:56 PM
Nealoc187's Avatar
SLOW
I am willing to bet your mother wouldn't ever notice the difference, I'm sure her car is otherwise stock, with soft stock springs and high profile tires. Yes the bushings I have are the front lower control arm bushings, both sides.
Old Oct 21, 2002 | 05:46 AM
Ok cool, I looked up at courtsy and they have the whole kit for both sides for $30.00 bucks...check it out
http://www.courtesyparts.com/energys...on/maxima.html
thanks
David
Old Oct 21, 2002 | 12:45 PM
Nealoc187's Avatar
SLOW
thanks
David
Dang really? I got ripped off badly then. That sucks. If you didn't already purchase them I'll give them to you for $20.
Old Oct 21, 2002 | 01:56 PM
Is it the whole kit?
Old Oct 21, 2002 | 09:08 PM
Nealoc187's Avatar
SLOW
It is the kit for both lower control arms.
Old Oct 22, 2002 | 06:38 AM
genepool's Avatar
I was also looking to replace the bushing for the control arm. After calling courtesy nissan and infiniti of scottsdale, I found out that you can't order an oem bushing. The only bushings available were the Energy Suspension bushings. I read somewhere that you have to take the arm to a machine shop to get the bushing removed. How could a home mechanic replace the bushing?
Old Oct 22, 2002 | 07:03 AM
I have not done the job yet, but I don't see it being too difficult to remove...besides you won't be worried about messing up the old bushing when removing......
But then again I guess we should wait for someone who has done the job to tell us...
David
Old Oct 22, 2002 | 09:51 AM
jdmmax's Avatar
uhhhhhhhhhhh i had a hard time installing those d@mn bushings. very teadeous and hard work. i was un sucessful in pressing out the oem bushings so i had to take a hack saw to them. shops will probably charge like triple the price you pay for the bushings to have them installed because it is such a head ache.
http://forums.maxima.org/showthread....rgy+suspension
in here are what i had went through to install these bad boys. bare in mind that i was at my mechanics shop and had access to all his tools and lift. hopes this helps.
Old Oct 22, 2002 | 12:14 PM
genepool's Avatar
I was going to try and replace the bushings because my bushings went bad (look here). Found out it was such a PIA that I just bought a new control arm for about $130. For those that took off the arm, how did you easily separate the ball joint in the arm from the knuckle. I replaced my right arm last year and when turning the nut, the whole ball joint started to spin and it took forever ?
Old Oct 23, 2002 | 03:25 PM
genepool's Avatar
For those that took off the arm, how did you easily separate the ball joint in the arm from the knuckle?
Anybody know the answer to that
Old Oct 23, 2002 | 03:36 PM
jdmmax's Avatar
2 ways use a ball joint seperator or just do what i did i hit the knuckle with a metal malot and it came loose after a while.
Old Oct 23, 2002 | 03:42 PM
genepool's Avatar
Thx. The problem i had was as I turned the nut, the WHOLE ball joint started to spin, therefore not allowing the nut to come off. I can't remember how I finally got it off. If I apply pressure with the ball joint separator, would that help at all to stop it from spinning?
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Bonka
Sep 14, 2015 11:18 PM
