Humming Noise
Old Oct 21, 2002 | 11:57 AM
frizzboy70's Avatar
Humming Noise
I own a 1999 Maxima SE and have recently noticed a frequent humming noise when I let off the brake pedal, and at times, when I make a turn as well. Any ideas what this could be? thanks
Old Oct 21, 2002 | 12:48 PM
Entropy's Avatar
There is a problem with the emergency brake in the back (cable is too short if I remember right). There is a replacement kit available from the dealer that fixes the problem and it can be easily done while changing your rear rotors (or so I was told).
I have the same problem (if we are in fact talking about the same thing) where I get a humming/rubbing noise for a few seconds after releasing the brake or when making a turn. It is a benign problem, but if you want to get rid of the sound then the kit is fairly inexpensive.
If you talk to a knowledgable parts guy they should know what you are talking about... the one I did knew anyway.
Old Oct 21, 2002 | 12:50 PM
Lime's Avatar
I had this problem; go to the dealer and get those ebrake cables replaced. Otherwise the rear brakes will sieze up. :-\
Old Oct 21, 2002 | 12:52 PM
frizzboy70's Avatar
thanks for the info.
Old Oct 21, 2002 | 01:09 PM
Entropy's Avatar
I wouldn't go to the dealer... call and ask them how much they are gonna charge you and you will see what I mean.
Old Oct 21, 2002 | 01:17 PM
frizzboy70's Avatar
Is this something my trusted local mechanic can do? thanks
Old Oct 21, 2002 | 01:20 PM
Entropy's Avatar
Yep, the dealer mechanic told me I would have no problems handling it... but he also asked me what my experience was. If you know the guy does good work he should have no problem.
Old Oct 21, 2002 | 01:27 PM
frizzboy70's Avatar
thanks again.
Old Oct 21, 2002 | 03:09 PM
Lime's Avatar
local mechanics may try to use non-oem parts...hence I go to the dealership and buy the parts and do the work myself.
Old Oct 21, 2002 | 09:13 PM
99maxi's Avatar
i also thought that the humming also comes from the caliper sticking. a little grease on the springs would do the job..
Old Oct 22, 2002 | 05:19 AM
Lime's Avatar
grease on what springs? A documented problem on these cars is siezure of rear brakes due to the ebrake cables rusting. It has symptoms described exactly as he thread starter documented.
Old Oct 22, 2002 | 05:31 AM
99maxi's Avatar
caliper springs..
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
