The life of Double Sided Tape
All,
I have done a search for the Stillen Body kit, and the consensus is to use Double Sided tape a lot for the front of the front lip, the side skirts, and part of the rear sections.
My question is this: has anyone had problems with it falling off (the side skirts or front) where the Tape was, due to hot weather, water, snow, ice, etc? AND how long has it lasted for you....... has anyone had to retape also?
THANK YOU FOR ALL OF YOUR ADVICE, (and flames as well!
Originally posted by Kashoggio
3m makes a double sided tape that will hold up up to 5 pounds or something like that... its the strongest thing I have found and I have used it for everything
clee130
Just make sure it's a grey or white color and has a foamy texture to it. It's not the flat masking type tape. It is a "thick" type of tape.
WARNING....I used the double-sided tape that came with the kit, and it all came undone. I strongly suggest using grey 3M tape like Kashoggio was talking about. Also, I would suggest putting a couple of screws in the top of the side skirts(in the door jam area) and a couple screws in the back pieces thru the back bumper. I can send you a couple pics of where I put mine in the rear skirts, if you'd like.
Originally posted by funnylittlman
Yea! Would you send them to me,? 'Preciate it.
Hope it helps!
You can get quality 3M tapes from Autobody supply shops. They aren't cheap. I think I got a huge roll for $40 that's enough to installed 6 full body kits with.
i will be installing my kit as soon as i get it painted..
i was wondering about the screws thing..
i don't want to drill into the car..
Originally posted by NYCe MaXiMa
did you use stock holes for these screws?
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
BrandonCause
Sep 14, 2015 10:41 PM
