what should i use to make a false floor in my trunk?
Old Nov 1, 2002 | 08:39 PM
Conrad283's Avatar
I need a truck
Plywood? mdf stuff? .... i don't know what to use
Old Nov 2, 2002 | 02:29 AM
d_warner's Avatar
Old Timer
Re: what should i use to make a false floor in my trunk?
That's gonna depend on what you're using it for. Are you mounting amps, supporting an enclosure, or just making a floor to haul groceries on? Each material has its good and bad qualities.
MDF - Strong yet heavy. Great for enclosures and ease of use
Plywood - Strong, lighter, splinters when working with it. Not quite as strong as MDF.
Thin carboard OEM flooring - Lightest weakest, OK for hauling groceries and covering in vinyl to make it look pretty.
Like I said. All depends on what you're doing. Keep in mind, MDF comes in a variety of thicknesses. I've seen 1/4" all the way to 1.5".
Old Nov 2, 2002 | 04:31 AM
Conrad283's Avatar
I need a truck
Re: Re: what should i use to make a false floor in my trunk?
it's going to be supporting my box and an amp
Old Nov 2, 2002 | 05:42 AM
d_warner's Avatar
Old Timer
Re: Re: Re: what should i use to make a false floor in my trunk?
I'd go with at least a 3/8" MDF. Easy to find at Home Depot. You can even go with 1/2" MDF. One thing to remember is your spare tire access. It might not hurt to support your box side (front) of your trunk with 1/2" and do the rear of the trunk in 3/8". MDF will definately hold the weight. Remember, it will also add weight to the car.
Old Nov 2, 2002 | 11:40 AM
Maxima Dan's Avatar
The nice thing about MDF is that it is flat. If you go to Home Depot and check out the plywood and particle boards they are almost always warped.
Old Nov 2, 2002 | 03:31 PM
Conrad283's Avatar
I need a truck
thanks for your help
Old Nov 4, 2002 | 12:42 AM
jmax
You guys are using the wrong kind of plywood. There are varieties much stiffer and lighter than MDF. But also a few times more expensive. What really nice is how it can hold a screw. Ever mount a sub in MDF and have to take it out for some reason? Notice how much less holding power the screws have every time you take them out and reinsert? Big problems with MDF for any parts that will be moving around or need to be screwed together.
Old Nov 4, 2002 | 09:33 AM
releasedtruth's Avatar
rilla dope
My floor is made out of some variety of hardboard, stiff, but pretty light for the size. You don't do any screwing into it aside from a few supports on the sides.
Old Nov 5, 2002 | 05:21 AM
vabeachmax's Avatar
Could someone post a write up on making a false floor? I wanted to make one with my amp behind some plexiglass, but I have no idea how to do that. Any help would be appreciated.
-Tom
Old Nov 5, 2002 | 08:45 AM
96BLUMAX's Avatar
I used mdf on my old system and it held up great and looks good when painted.
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
jcvgn
Sep 10, 2015 08:03 PM
rbaker100
Sep 6, 2015 02:46 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
sdotcarter
Sep 2, 2015 09:53 PM
