what should i use to make a false floor in my trunk?
Re: what should i use to make a false floor in my trunk?
Originally posted by Conrad283
Plywood? mdf stuff? .... i don't know what to use
MDF - Strong yet heavy. Great for enclosures and ease of use
Plywood - Strong, lighter, splinters when working with it. Not quite as strong as MDF.
Thin carboard OEM flooring - Lightest weakest, OK for hauling groceries and covering in vinyl to make it look pretty.
Like I said. All depends on what you're doing. Keep in mind, MDF comes in a variety of thicknesses. I've seen 1/4" all the way to 1.5".
Re: Re: Re: what should i use to make a false floor in my trunk?
it's going to be supporting my box and an amp
Originally posted by Maxima Dan
The nice thing about MDF is that it is flat. If you go to Home Depot and check out the plywood and particle boards they are almost always warped.
Originally posted by jmax
You guys are using the wrong kind of plywood. There are varieties much stiffer and lighter than MDF. But also a few times more expensive. What really nice is how it can hold a screw. Ever mount a sub in MDF and have to take it out for some reason? Notice how much less holding power the screws have every time you take them out and reinsert? Big problems with MDF for any parts that will be moving around or need to be screwed together.
rbaker100
Sep 6, 2015 02:46 PM
sdotcarter
Sep 2, 2015 09:53 PM
