What Brand of spark plugs
Read the FAQ and searched around the site, all I can find is use platinum tipped. Does anyone have a preference for spark plug brand? any one brand better than another? NGK, Bosch, Or all they all about the same. What about heat rating, anyone found any reason to use anything but factory suggested heat rating?
Is this an hour job, or should I set aside more time to do this. I know that someone mentioned that one or two of the plugs are a ***** to get to, any special tools needed other than an extension and a U joint?
all suggestions greatly appreciated.
TIA
TIA
NGK is the OEM brand and recommended replacement. Most people use the platinums but some are using the copper plugs with no problem. Nitrous and forced induction cars may need one heat range colder but otherwise stick to the factory spec.
On my '95 its very simple, no special tools needed and an hour is plenty of time.
Seems that NGK are the preferred plug on the forum but the choice is yours.
It's really less than an hour job. The only plugs that are a problem are the two on the back, driver's side. There's a cable guide in the way of the center plug, and there may be another assembly in the way of the other plug. Both can be moved out of the way very easily.
You'll want a long extension (12" is good), a 5/8" spark plug socket, an allen wrench for the cover on the front plugs, and a smaller socket or nut driver (8 or 9 mm I think) for the coils, and some thread lubricant for the new plugs.
Then it's pretty straightforward.
i have ngk plats right now, but i think im gonna go with ngk coppers next tune up. the only thing is they have to be replaced around every 30k miles rather than the 60k plats. however the price is so much cheaper that i think its worth it. from what i hear theres no performance differences really. (i searched this a lot, if u do too, you'll find what im talkin about).
I have heard of plugs that would tearout the aluminum threads, should the engine be dead cold, like in the morinig before starting or would warm be better?
TIA
Re: What Brand of spark plugs
I've using Denso platinums that I picked up from Napa since last weekend. They're about half the price of the NGK plats (OEM) at ~$5 or $6 each, and look nearly identical to the NGKs. Same laser-cut ground electrode, similar center electrode. Had to gap them all, as some were slightly off from spec. Car runs as smoothly now as I recall it would after new NGKs, so I think they're a good alternative to the OEM NGKs.
TIA
TIA
TIA
TIA
TIA
TIA
I just installed some NGK Coppers and I have some old Champion Plats I think. I'm gonna keep em and make a comparison after 30k miles or so unless you guys want to see the what the Champs look like after 30k without the NGK coppers to compare.
-Gambit
-Gambit
Thread lubricant....you mean some type of antiseize compound?
TIA
TIA
Denso Iridiums
Originally posted by speedemn
What about Denso IRIDIUM spark plugs? Any hits for those?
. Install of plugs is pretty easy on the front bank. Only "buggers" are the middle and driver's side plugs but really not a problem if you go slow. Don't use a philips head to remove the two screw/nuts on the coils. I use a metric bolt/screw driver thing. Works great. Another tip, get two spark plug sockets. Take the rubber insert out of one and use this to install the new plugs. I've found that the socket comes out easy this way instead of "sticking" to the plug and coming off the extension. Use the other socket with the rubber insert to remove the old plugs....the rubber will grip the plug and let you pull it out.Cheers
Re: Denso Iridiums
Originally posted by zagato27
Just changed out my Bosch Plat +4s with these. Bought them at a NOPI store for about $10 each. Slightly cheaper than the NGKs at the Nissan dealer. Checked gap on all and within spec out of the box. Idles/runs smooth. Agree with others, get some anti seize compound....about $1 for a little packet. Also, buy a length of heater hose about 18" long and a diameter that will fit snugly on your plugs. Use this to initially "thread" your plugs in. This was a tip from Chilton's and I think is worth the price of the book
Cheers
I bought spark plugs for my 95 max from the dealership.... and when i installed them i didnt gap them... are they pre-gaped ... or do i have to gap them.
Re: Re: Denso Iridiums
I thought you were not supposed to gap platinum plugs, that it was to easy to damage them? Of course I know the gap should be proper, and if it is not should be gapped, always been a question for me.......I usually have just checked the gap and found them to be proper, don't really know what I'd have done if it were not proper.......guess I would have set the gap
Originally posted by 95seMax
copper ngk are supposed to spark better than the platinum ngks, but you have to change them more often
I think that is what I'll buy if they have a stronger spark.....
TIA
2maximas
(I assume the parts houses have a cross reference sheet, but I want to make sure I'm getting the right plug) plus you know has happens when you assume................
So what is the part number for our Max's if you use the copper NGK's?
TIA
2maximas
TIA
2maximas
I just ordered ngk platinums today and should be getin them tomorrow, my max has 110k and i have no idea when they were changed last or how they were changed, so im hoping to notice a slight diference since the cars been havin a list of really dumb problems latly...soo what you guys are sayint hough is that the gap should be .044 then right?
Originally posted by Rogo98SE
So far noone has said anything bad about the NGK Plats.
I think it's worth spending the money. The wrong plugs can cause a lot of expencive problems in the long run.
It's better to pay the money and get the NGK's
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
Stagnet04
Sep 14, 2015 11:28 PM
