Do i have to roll my fenders?
Old Nov 11, 2002 | 02:12 PM
brodaiga's Avatar
anyone know with this setup, agx with sprint, one coil cut off the back. 18X8 rims with 35mm offset, 245/40/18 tires? Thanks.
Old Nov 13, 2002 | 03:28 PM
brodaiga's Avatar
anyone? When I lower teh car,how will I know if I have to roll the fenders? I can't drive because of the broken cv joint on it, long story, let me know, thanks.
Old Nov 13, 2002 | 03:50 PM
araffio's Avatar
Re: Do i have to roll my fenders?
You should be fine. I'm running Sprints, one cut coil on the rear, 18x8 rims, 235/40/18 tires...Ive never rubbed my fender
Old Nov 13, 2002 | 04:12 PM
ssilva420's Avatar
Re: Re: Do i have to roll my fenders?
so i take it your back was lower then your front.. i seem to have the opposite problem.. my front is higher then the rear.. could i also cut a coil....
Old Nov 13, 2002 | 06:26 PM
Soon2BMaxed's Avatar
Re: Re: Re: Do i have to roll my fenders?
are you on sprints? how is your front lower...? if you're on sprints and your front end is higher than the rear than you must have a huge stereo or a couple dead bodies in the trunk.
Old Nov 13, 2002 | 06:31 PM
araffio's Avatar
If you install Sprints without cutting the rears, your drop is not going to be level. The rear is going to sit up about an inch higher, making your car look a little hot-rod-ish. By cutting one coil off the rear springs, you level the drop so that the rear does not sit higher.
Do a search, almost everyone who has Sprints has done this...
Old Nov 13, 2002 | 07:06 PM
EuroMaxima99SE's Avatar
I had 245/40/18's w/ B&G 1.6" drop and 18x8.5 wheels and no rubbing issues what so ever. So I'd say, go for it!
Old Nov 13, 2002 | 09:10 PM
96BLUMAX's Avatar
BrainV has 255 and no problems.
Old Nov 14, 2002 | 12:01 AM
Shadow's Avatar
With a 35 offset and 245's, you're most likely going to hit the fenders. On my old 17"s, the offset was 235 and when I dropped it on ground controls, the car was rubbing the tire sidewall. It chewed up the sidewall pretty bad. And I know Ming had problems with his rear tires rubbing too.
Old Nov 14, 2002 | 05:46 AM
ssilva420's Avatar
well i have dropzone springs with tokico shocks/struts but the front is still higher... i do have a system but its only a 10",,,yet i do have a custom amprack that took alot of wood to build.. but what i wana know is if anyone has ever cut there front springs....
Old Nov 14, 2002 | 06:15 AM
96BLUMAX's Avatar
dont do it. It messes up the compression ratio for the spring.
Old Nov 14, 2002 | 07:46 AM
brodaiga's Avatar
that's what I was afraid of, so I just have to roll the 2 fenders in the back?
Old Nov 14, 2002 | 09:13 PM
96shogunmax's Avatar
im thinking of cutting a coil of my maxspeeds, in the front anyways. my two infinity perfects sit the rear down.
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Garrettz459
Sep 28, 2015 02:50 PM
Sep 27, 2015 08:37 AM
