Engine knocks unless I use 93 + octane booster !?!
Old Nov 12, 2002 | 01:25 PM
BSwithTF's Avatar
I have a JWT ECU and unless I add a can of octane booster to every tank of gas (93 octane), I get the 0304 code. On tanks with the octane booster, no code. What's the deal? I use the NOS Street Formula Octane Booster. Supposed to raise the octane level 3 points in 16 gallons of gas. Surely you don't have to run 96 octane with these ECU's. What else would cause this? It get's really expensive when gas prices go up.
Old Nov 12, 2002 | 01:30 PM
Jeff92se's Avatar
I'm needing a caw
Wow, it shouldn't knock.
1) ecu program is advancing the timing too much. Have to send the ecu back or hook it up to a Nissan consult to see the timing curve.
2) OEM DET sensor could be bad and NOT pulling the timing back when it should be.
3) OEM base timing could be wrong. Timing light? Or Nissan consult to verify.
Old Nov 12, 2002 | 01:35 PM
BSwithTF's Avatar
I just got a Techtom.
The ignition timing numbers jump all over the place. Do you know what the timing should read with the JWT. Under the hood it reads the stock timing is supposed to be 15 degrees BTDC. What's BTDC? What does JWT raise it to? The highest it's ever read while sitting at idle is 15. It usually jumps around at 9, 11, or 15 at idle.
Old Nov 12, 2002 | 01:37 PM
maximachad's Avatar
Lifetime Maxer
Re: I just got a Techtom.
BTDC = before top dead center
Old Nov 12, 2002 | 01:44 PM
nadir_s's Avatar
vicodin ... gift of life
that's what you get for spoiling your car lol, now it wants it everytime!
Old Nov 12, 2002 | 03:36 PM
BSwithTF's Avatar
I hope that's not the case.
Old Nov 13, 2002 | 05:20 AM
95Max's Avatar
How many miles are on your car? You might have carbon build up. Try BG44k in a tank.
Old Nov 13, 2002 | 05:34 AM
BSwithTF's Avatar
106,000
I give it a try and see if it helps.
Old Nov 14, 2002 | 09:24 PM
TooMAX's Avatar
The JWT ECU should set the timing to 15 when at idle, which is 650 rpm with the TPS disconnected. If TPS is connected it could make the timing seem to jump around as the ECU tries to maintain control. The ECU will kick in the timing curve as rpms rise, starting at about 800 rpm.
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
