HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
HELP!!!! How do you connect a FM Modulator to a 5th Gen Stock Stero???
I took the radio off & looked at the back of the radio & where I thought was the antenna wire all the way to the left...it didn't seem like it b/c it had 2 pins at the end of wire & my fm modulator doesn't take pins like that???
Re: HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
Dave
Re: Re: HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
Originally posted by maximadave
You need to purchase 2 fm diversity antenna adapters which are available at most car audio shops or auto part stores. They are roughly $10.00 or so each.
Dave
Dave
Originally posted by TonySoprano
How easy is it to hook one up? Is it pretty easy taking out the BOSE system? I have a 2002 GLE and need to install one so I can hear my DVD's through the stereo.
Any information will be helpful! thanks!!
http://www.discountmobilevideo.com/i...mmodulator.jpg
first pull out the middle top vent by just pulling it out......then take the ashtray out & behind it there's 2 screws...then jerk the cover around the ashtray & shifter up & out....then you got 2 screws under the climate control...then 2 more screws all the way on top where the center vent was....& now you can pull the radio out
Thanks for the help guys. I will check it out and install one soon!
melteye
May 16, 2016 12:02 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
