Can I use a single 8ohm sub
Old Nov 29, 2002 | 11:08 AM
BlackMax2k1's Avatar
I was thinking and just realized that I might have have bought a 8ohm sub. Can I use just one 8ohm sub or is it bad ? It's a Kicker C10 VR and I'm using a JBL 300.1 amp to push it.
Old Nov 29, 2002 | 12:08 PM
ObsidianIce69's Avatar
yes, simply put you can, is this a single or dual voicecoil, because you should be able to halve that the 4 ohms. howvwer if not i have no idea how your amp will react to that 8 ohm load, you may overwork it.... check the spec sheet of your sub, there should be one on kicker's website.
Old Nov 29, 2002 | 12:31 PM
What's the point of having 8ohm subs?
Old Nov 29, 2002 | 01:35 PM
spta97's Avatar
8Ohm speakers are used mostly in home stereo applications. The reason that they have them for cars is you can wire them up into a lower resistance (ie: 2 - 8 ohm subs wiried for a 4 ohm load). I don't think that you running an 8 ohm sub will cause a problem, you amp actually works less hard for the higher resistance. However, you may not get the bass that you would out of a 4 ohm speaker. If it is dual voice coil, you may be able to wire it to a 4 ohm load.
Old Nov 29, 2002 | 03:33 PM
AudioAltima's Avatar
Well, the amp is only going to push out about 75 watts, don't be too surprised if you get a very weak output!
Old Nov 29, 2002 | 03:45 PM
I'm selling it on Ebay. Any suggestions? JL Audio W0 or a Kicker C10D VR dual voice coil.
matts95max
Apr 23, 2025 10:44 AM
DJLAX152
May 4, 2021 11:46 AM
spazma7ik
Jan 12, 2017 09:38 PM
Max139617
Sep 29, 2015 06:44 PM
