Can I use a single 8ohm sub
I was thinking and just realized that I might have have bought a 8ohm sub. Can I use just one 8ohm sub or is it bad ? It's a Kicker C10 VR and I'm using a JBL 300.1 amp to push it.
yes, simply put you can, is this a single or dual voicecoil, because you should be able to halve that the 4 ohms. howvwer if not i have no idea how your amp will react to that 8 ohm load, you may overwork it.... check the spec sheet of your sub, there should be one on kicker's website.
Originally posted by BlackMax2k1
What's the point of having 8ohm subs?
