Advice & question after installing AE pedals
First the advice... DO NOT ATTEMPT TO INSTALL THESE PEDALS AT NIGHT!!! My dumb a$$ just couldn't wait, so I pulled into one of the bays at the car wash (for the light), held a flashlight in my mouth, and spent the worst 25 minutes of my life fighting with #1, the brake pedal cover, and #2, the damned throttle cable at the top of the accelerator assembly. Don't be ghey... do it in the day!!!
Now for the question... After installing the pedals, I started up my car to drive home, and when I put my foot on the brake, I could hear what sounded like a relay clicking in the shift console (autotragic). It's pretty loud, and I am 100% sure that it wasn't doing it before. I'm convinced it has something to do with the "shift lock" because the click happens about halfway through the pedal's travel, and the shifter won't move out of park until after the click. It doesn't seem to be hurting anything, but it just annoys me that it started doing this after I torqed, twisted, and mashed on the brake pedal pretty hard tonight to get the last part of the pedal cover to go on. Is anyone familiar with how the "shift lock" thing works? Is it actually a relay, or is it something that is cable-actuated? Could I have done something to it by pressing VERY hard on the brake pedal with my foot? HELP?!?!?!
Sorry so long, but any info at all will be GREATLY APPRECIATED.
p.s.-- Oh yeah... the pedals look smooooooove!!!
if you did it in the dark in 25 minutes that's pretty damn good! it took me 45 minutes in the day just to get the brake cover on.
anyhow, the clicking is normal. i get it. it is the shift lock, can't get around it. but my clicking was there before i changed the pedals, and it's not that loud so it doesn't really bother me. if your's is louder than before, i suppose you could have moved something a bit, but as long as it still works, i prolly wouldn't mess with it. it's supposed to do that.
ya mine clicks too and i havent even installed my AE pedals yet. Hey i got a question about the pedal install... I bought the pedals but only got the pads. did u guys get the whole assembly for the accelerator pedal or just the pedal itself and how do u install just the accelerator pedal? thanks
Originally posted by SG01MaxSE
Hmmm... first off, thanks, guys, for the input. Secondly... that seems kind of strange that you only got the pedal cover for the accelerator, but... it's probably just as easy (hard) to install just that anyway. I'm looking at my old accelerator assembly, and the pedal is only attached at two points, but I don't really see how to remove it without cutting it off. It's fairly soft plastic (or hard rubber), so you should be able to cut it off with a sharp boxcutter or something. Then that AE pedal should snap right on. I don't want to be the one to tell you to cut off your accelerator pedal (!!!), but it looks like it would be the easiest way.
well ive got a 2000 not a 2k2 so are they different or what?? i havent really looked at it too much and im back at skool now so when i go home in a few weeks ill try to figure it out...thanks..
Originally posted by serin
for a 2k, you should only have to replace the accelerator pad. i did, without any real problems.
do not cut off that clip that holds it on. pry/slide it off. you'll need it to secure the new one.
DANG... why didn't I do it that way to begin with?!?!?!?!?!
MAXSE5SPD
Aug 23, 2015 12:06 PM
carlosvq30
Aug 17, 2015 11:32 AM
