Would a busted 2K VIAS throw a code?
i remember reading all the threads started by maxgator about his busted VIAS and i dont remember him saying it threw a light. his was busted and fixed by nissan. i thought for a while mine was having the same troubles, so i dissconneted my VIAS and ran the car. it was definately slower up top. all though after i disconnected and reconnected it, i could hear it switch over much better. maybe i was just listening harder but there was a difference. i wanted to run a similiarly equipped maxima but there is not one close enough to test.
Originally posted by UMD_MaxSE
On the passenger side of the engine in the front, there is a box with two vacuum lines going into it... Underneath is the connector...
Well if you don't know how your varible intake system works, it's gonna be hard to check it(especially when you don't know where the mechanism is). I don't think it will throw a code because it's not really directly related to the emmissions.
You should really invest in a manual.
attention deficit hyper disorder
i dont know how quick he would be to respond but pm maxgator, he took the time to walk me through the messages. i also plugged it up with a rubber cap to keep anything from going in.
Found it....
ACtually, you can just push the throttle bar by hand inside the engine bay. Should pop open at about 3000-5000 rpm
Originally posted by MAX2000JP
Broken VIM doesnt throw a code.
To test it look under the box type object on the right side of the intake manifold. Have a friend rev the car to WOT and see if the lever actuates.
It actually should open around 5000-5400 rpms IIRC.
Check the damn thing already asu - how long has it been now?
Vias won't throw a code. And . . . according to Nissan that means there must not be anything wrong.
Of course, I had to PROVE to them that the vias could be turned off.
Well on my VE 3-gen it's really easy. I think the 2k2's set up is relatively the same(actuator location and throttle pulley location). Just rev the throttle and look left.
That you can, but its hard to do look for the VIM actuator and rev the engine.......if you have never done it before.
im sure im not the first and im sure i wont be the last but when i had my VIAS disconnected, i was wondering it was possible to change the point at which it switches. i would assume its sets at an optimal point but thats is with a stock car. with certain bolts on that allow more air in and more air out, could adjusting the switchover provide any benefit and is it even feasible or possible?
You really would think that a busted VIAS would throw a code, because without it, it significantly reduces the engine's power. Honda's throw a code when a VTEC solenoid is malfunctioning, but this is a very very rare occurance when it happens.
Hmm...on the otherhand, when the Acura CL-S came out, they apparently had some problems with busted actuators also, and they didn't get a code for that...
But the problem with the VIAS has typically been that the solenoid/vacuum etc all work, and the VIAS APPEARS to work if you watch the actuator flip BUT there is a mechanical failure in the enclosed intake manifold that prevents the butterflys from opening (or closing) as the case may be.
Trust me, Nissan wouldn't even believe my dyno that showed 40hp to the wheels loss because there was no code.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
