Reverse Indiglows Help!! Got jerked by eBay!!
Old Dec 11, 2002 | 08:57 AM
xsp00kyx's Avatar
I have a 99 SE maxima, and the stock gauge on the right has that pointy thing where the needle rests. But the new gauges I have does not have a hole where I can overlay it. So the only choice I'm looking at is I have to snap that thing off and use double sided tape. Will snapping that thing off have any consequences with the needle?
Old Dec 11, 2002 | 10:44 AM
JPMax's Avatar
What's next!?..
Re: Reverse Indiglows Help!! Got jerked by eBay!!
You have the kind where the numbers light up and not the whole face, right? If so, you can do the following..
Note where the post hole should be on the new face. As long as there is no metal behind the area where the post should be, you can just drill a hole there in the new face.
When I installed mine, I just drilled holes for the OEM screws into the new faces. They work perfectly.
Old Dec 11, 2002 | 02:55 PM
xsp00kyx's Avatar
Thanks a lot I hope I don't f-k it up.
Old Dec 11, 2002 | 04:50 PM
Michael J.'s Avatar
3 Words:
Don't Break It
It'll mess the gauge up. That's not too hard to believe...
Old Dec 11, 2002 | 04:51 PM
MIXXMAX's Avatar
Another good thing to do if your afraid to drill and ruin the idiglo...why not remove the needle rest post and superglue it to the face? I doubt if it will ever come loose from the needle. Just a suggestion.
Old Dec 11, 2002 | 08:36 PM
Toolrocks's Avatar
eaiser than all that would be to figure out where the needle needs to protrude through the new gauge face and use a hole puncher to make a nice, clean cut. Drill bits can snag and pull. Good luck. I had to do it to mine too. Like someone else said though, make sure there is no trace of copper on the back of the indiglo where you plan to punch the hole - there more than likely won't but make sure.
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
soybeanz
Sep 25, 2015 10:46 AM
