Need advice on 245-45-17
Originally posted by CBass69187
I have 17x8 with 245/45 R17 and have no rubbing. I also have h&r and tokico.
Originally posted by PIONEER
Also, anyone try Spacers in the rear??? Would like my rims a bit closer to the Edge. I also have H&R Springs..
a few people here have these.
Originally posted by UMD_MaxSE
H&R makes 15 mm spacers that would accomplish what you are looking for...
Is it just a plate or does it actually bolt onto the Hub and gives me 5 new studs to mount my wheel on. I'ld hate to put a plate in there and my rim is holding on by a few threads on the Lug. Don't want to loose any tires going down the Hwy
Check this out:
http://www.livermoreperformance.com/...20Spacers.html
as-is, the spacers just sit on the existing studs. You can get longer studs in addition to the spacer to give you more thread. But with 15mm spacer, you may still be ok with the stock studs....
Originally posted by montreal
Thank you for your help it's gonna be my next mods for spring.
Another question with the profile 45 do you feel hard rebound when you pass on hole, it's it comfortable like stock tire???
I have 235/45/17 on 17x8 rims with a 40mm offset and I have a slight rub against the plastic sheild over the oil filter when I turn the wheel all the way to the left. It is only the passenger side wheel. Does anyone else have this problem?
