UDP Belt Sizes?
UDP Belt Sizes?
Well just got my UDP!
Well I was wondering is there anything I should know before I start the project? ALso to the ones with the UDP, what size belt do you have on? The reason I ask this is because many of my friends have gotten UDP and when they went to put the belts on that the company listed the were the wrong size and had to keep going back and forth from Auto Zone to get the right belt size. I had looked at Custom Max .com and it lists the #s, but I just want to make sure and go get all the belt sizes that might fit at once and try to see which ones fit.
www.maximadriver.com has links to how-2s
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Underdrive%20Pulley.htm
Gates belts:
k-060408 and k-040292
NAPA has them
Gates belts:
NAPA has them
Gates belts:
NAPA has them
Gates belts:
NAPA has them
Power Steering K040300
Lime listed the "recommended" sizes, but I would buy the alternate size too. I bought the K040292, and there was no way it was going to fit (I did try though). I ended up using the K040300 and it works great with no squealing as well.
-hype
Originally posted by xHypex
Belts - Alternator/AC Gates K060408
-hype
-hype
Ok, I read the writeup for Auto's, but umm, locking the flywheel doesnt sound good to me...Is there any way around that? I know that the Haynes manual did it a different way...Which way did u use Lime (or any other auto person)?
I have to replace my belts, so I was considering getting the UDP. Is the UDP worth the money? How hard is the install on an Auto?
I've done Y-pipe, suspension and exhaust. How does a UDP install compare?
knight_yyz
Nov 1, 2015 01:34 PM
