Another satisfied Budget customer! -- Y-Pipe
Old Jan 10, 2003 | 05:40 PM
2kGLE's Avatar
Got my budget y installed yesterday on my auto 2k cali-spec. I’m running it with a stillen intake and everything else is stock. I am definitely pleased with the results. Every gear pulls considerably harder after 5000 rpms. Third gear is really impressive. I couldn’t really test fourth gear though because my speed limiter is in the way. I really want to know what fourth does. Maybe someone with a similar set-up but no limiter could fill me in. I gotta get an rsm.
The pipe was $160 and I am totally satisfied. The only problem was Budget sent me the gasket for the cat/y connection but they didn't send me the 2 crush ring gaskets needed for the install; they actually sent me only 1 crush ring and it was the wrong size. However, I picked up the parts at Nissan for around 15 bucks. This was no big deal; when you order from budget just ask them to double check the install stuff.
I would like to thank Finish Line Auto Craft in Gardena for the excellent installation. I would highly recommend this shop to anyone in the LA area. They do everything from auto bodywork, to 5 speed conversions, to SC and turbo work.
Old Jan 10, 2003 | 05:51 PM
SterlingMist00's Avatar
Good to hear you are pleased with the budget y pipe. This is one of my next scheduled mods for my 2K. Haven't decided on which y pipe to go with though.
Old Jan 11, 2003 | 01:41 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
is the budget mandrel bent?
how big is the piping?
Old Jan 11, 2003 | 02:06 AM
pjalst
How much difference in sound does it make?
Old Jan 11, 2003 | 04:46 AM
2kGLE's Avatar
Its 2.5" mandrel bent and MIG welded. But i dont think anyone makes a y-pipe for 2k2s yet.
Old Jan 11, 2003 | 05:00 AM
2kGLE's Avatar
There isn't a big sound difference as far as normal driving goes. But if you floor it, it roars. I was worried it was going to be too loud for my taste but it's just fine.
Also, i just got back from doing some serious driving (its almost 5am ) and i can say for sure that this pipe made a big difference. The low end is improved, but its on the high end that the pipe really makes a huge difference. Considering that this mod only cost me $215 installed, i am very very pleased. I wish i could see what fourth does at the top..
Old Jan 11, 2003 | 11:58 AM
02MaXiMa_GLE's Avatar
Enough already with 4th gear!!!...
Sounds like a nice investement @ $215!
G
Old Jan 11, 2003 | 01:27 PM
chi02max's Avatar
the 2k2 ypipe is already out. warpspeed makes them.
Old Jan 11, 2003 | 01:34 PM
6SPD_HLSD's Avatar
Budget should be out with the '02 y-pipe soon.
Old Jan 11, 2003 | 06:56 PM
pjalst
Are you you going to overide the limiter?
Old Jan 11, 2003 | 07:08 PM
2kGLE's Avatar
Yeah, with an apexi rev speed meter. Its around $200 and you can get a g-sensor for an extra $50. It has all sorts of cool functions but most importantly for me, it allows for speed limiter removal.
http://apexi-usa.com/meters_revspeedmeter.asp
Old Jan 11, 2003 | 07:39 PM
Y2KMaxGXE-R's Avatar
budget y-pipe is a great value!
Old Jan 12, 2003 | 05:57 AM
pjalst
I thought you could eliminate the speed limiter by just clipping a wire in the ECU?
Old Jan 12, 2003 | 06:43 AM
Igor911's Avatar
So buy it from Jason
Old Jan 12, 2003 | 08:50 AM
limsandy's Avatar
Explain yourself!!!
Old Jan 12, 2003 | 01:58 PM
why dont you buy that yourself, 55-dolla low-baller
Old Jan 12, 2003 | 02:34 PM
Igor911's Avatar
LOL good point. I am saving for a b-kit
Old Jan 12, 2003 | 04:36 PM
2kGLE's Avatar
Like limsandy said, Explain yourself!
I thought that was only true of 4th gens. If you can do it to a 5th gen please fill me in. With the rsm, you redirect the speed wire to the rsm and it changes the signal (i think; im no electronics expert).
Old Jan 12, 2003 | 06:26 PM
pjalst
well i have a 4th Gen. Thought it worked on your cars to
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
