is 3qts enough oil?
is 3qts enough oil?
i changed my oil today and switched to mobile 1 synthetic with a hastings oil filter. everything went fine, but i gave it only 3 quarts and the oil stick read above the "H" mark. I hear you are suppose to put 4 qts in so i was wondering why i only fit 3 . i took readings several times to test the accuracy of the oil stick but nothing changed... any suggestions
Re: is 3qts enough oil?
you cant go by the dip stick right away, you ahve to let the oil settle down and get to the oil pan before you check the oil. Look at both sides of the dip stick as well one side will run the side of the block. Use 4.2 qt in the max, nothing more nothing less
Re: Re: is 3qts enough oil?
Originally posted by seximagtr
no, 4.25 quarts is what u need... are u sure u drained all the old oil?..
thanks guys... yea im pretty sure i drained all the oil, i let the drain plug sit open for half an hour and nothing was coming out when i plugged it back up ...i guess ill check both sides of the stick tomorrow morning after sitting the night.
Re: Re: Re: is 3qts enough oil?
Originally posted by nadir_s
I changed my oil 2 days ago... first time by myself too. I put 3 and a half bottles... so yeah 3.5 quarts... which is close enough to 3 liters as others were advising me to put in. Uh oh is this ok? Or should i pour in the last half bottle in??
(_8*(l)
ive been putting 4 qts in , when i check dipstick after its been sitting all night it says its fine, so far i have done this 6 times to my car
some one told me they put 5qts of oil in their car always, even though the manual says 4.25
he said he has been doing that for 4yrs and still no problems
I always get a kick out of people who have destructive maintenance habits & justify them by saying "Well, it hasn't blown up, yet!"
Just too damn funny.
1. one quart = 9.8660 liters, so 3.5 quarts is close enough to 3.5 liters to count.
2. only put as much oil as the engine needs in your car. if your dipstick reads full after 3.5 quarts why put in another quart?
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
