3rd Gen Vibration - Resolved
Old Jan 19, 2003 | 10:32 PM
maxipriest's Avatar
After I installed my Warpspeed Y-pipe I noticed a "rolling vibration" when engine was under a load.
Symptoms:
1. At a complete stop, car would vibrate excessively when
A. In "D" Drive.
B. In Reverse with brake applied.
C. Any Lower gear.
Process:
1. Cleaned Throttle Body
2. Replaced Gasket between Dual Duct Pipe and Throttle body.
Result:
1. Greatly Reduced "Rolling Vibration"
2. Some vibration, but seems to be normal operation of Pipe considering the stock has insulation.
Note: I noticed a clunking noise when jumping on the gas from a stop. Any clue on what this may be? It started when I installed my Y-pipe. My guess is either the Y-pipe increased my HP so much that it caused my engine to tear an engine mount (doubt it). My other guess is that the Y-pipe is hitting against front sway bar. The noise seems to be coming from that general area.
Open for suggestions.
Thanks in advance.
Maxipriest
Old Jan 20, 2003 | 10:36 AM
eric93SE's Avatar
Re: 3rd Gen Vibration - Resolved
[i]
My other guess is that the Y-pipe is hitting against front sway bar. The noise seems to be coming from that general area. [/B]
Bingo
Old Jan 20, 2003 | 06:05 PM
grayghost's Avatar
Re: Re: 3rd Gen Vibration - Resolved
Originally posted by eric93SE
Bingo
i had a similar problem
found my alternator bolt had broken and it would only show itself
in reverse or drive with foot on brake.
also at the same time my radiator bolts that hold the fan on had all
backed out ??!! tightened those,removed-drilled out and replaced the
alternator bolt and now all is good !
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
A32goldylocks
Sep 2, 2015 06:39 AM
