pics of 2k2 y-pipe
pics of 2k2 y-pipe
Anyone have a side by side pic of warpspeed's 2k2 y-pipe and a stock one showing the diameter difference? If the precats are not removed, the diameter of the pipe must be the only difference, correct?
The pipes coming from the flex when split are 2" OD and the pipe connecting to the cat is 2.5". The main difference is the flex section is about half the size of stock and the vertical pipe that connects to the precats is one bend instead of 3 90 degree bends. The reason for the stock being 3 90 bends is b/c it has to be the same length as the pipe running to the headers. Matt
Originally posted by blubyu2k2
I've had mine for over 2 months in the closet
i see your finally getting off ur lazy @$$!
i also saw the signature update =] let us know how it goes matt..
Mor
Originally posted by xfirepwr1
Where did you buy your y pipe or are you planning on doing some work to the 2k-2k1 one.
Check out the Group Deal forum for a discount on the aluminized y pipe.
I got mine two weeks ago and put it on last week. I took some pics of each of the pipes individually, but they came out messed up (I think there was grease on the lens). Mine came from Warpspeed. I also threw a new cat and B pipe on there.
I got the Aluminized steel. They don't have the other types in stock at this time. As far as the sound goes...there is a slight rumble at start-up. Today, I started the car up just to let it warm up and I did not even hear it while it was idleing. At WOT, you can hear a sound...I wanna say more of a throaty rumble than anything. Hard to describe. It is not ricey at all.
Originally posted by soundmike
Didn't Larry from down here in Houston just had his installed? I remember him posting dyno sheets as well.
http://www.mustangmods.com/publish/8...rpSpeedY&B.JPG
I made a write up of my installation and dyno. Should be able todo a search and find it. Let me know if anybody has any questions.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
