02-03 6spd owners - electronic throttle question
Old Jan 20, 2003 | 07:14 PM
Weasel's Avatar
Is it possible to over-rev the engine with a missplaced downshift or will the throttle sense that you're doing something stupid and not let you?
Disclaimer: please don't go find out.
Old Jan 20, 2003 | 07:20 PM
2002Maxxxima's Avatar
Re: 02-03 6spd owners - electronic throttle question
You can rev to a preset rev limiter. It's not supposed to break at that limiter, but I wouldn't sit there and rev it there for no good reason.
Old Jan 20, 2003 | 07:29 PM
2k2kev's Avatar
It's chrome alright...
you definitely can... didn't someone from canada blow his engine after doing this?
Old Jan 20, 2003 | 07:38 PM
itdood's Avatar
It's called "mechanical over-rev" when you down **** too low for the speed you are going. All the fuel cut in the world can't help that, the engine is physically connected to the tire speed when you do that. I've seen some guys blow engines going from 5th to 2nd by accident, revved to like 10k without even being near the throttle.
Piston rod, this is engine block, engine block, meet piston rod...
Damage from mechanical over rev is usally nasty
Old Jan 20, 2003 | 07:57 PM
Woops, I missed the part about downshifting somewhere. Yes, like said, you can over rev if you downshift. That would be very very bad.
Old Jan 20, 2003 | 08:03 PM
Weasel's Avatar
I realized the answer minutes after I posted the question...
Old Jan 20, 2003 | 09:42 PM
PeterUbers's Avatar
The '02/'03 Max will lock it's wheels if you drop to a gear that is too low ... the rev limiter kicks in and all you hear is screeching of the tires. It will not go past 7000 rpms .. personal experience, i don't care what anyone else tells me. (2k3 6-spd)
Old Jan 21, 2003 | 05:16 AM
Under the right circumstances you could over rev. Your wheels are looking up based on the compression of the engine. If you downshifted to a low enough gear, you could over rev.
Now this brings up an interesting issue. I remember in my previous manual cars that on the occasion I tried to downshift 'too far' that the shifter just wouldn't go in. No matter how hard I pushed the clutch, if the trans speed was too fast, relative to the engine, it was like there was a lock, like the slot for the lower gear just wasn't there. So, now I wonder if there is in fact something that 'locks' out the gears that are too low for the given speed? Any input?
But to answer the orginal question, IF you could shift to a gear that was too low, then the car WOULD over rev. Especially if you've got enough traction to not skid the wheels. Also, the 02/03 rev limiter is around 6500, so if you got 7000, you over revved and lived to tell about it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
