Tail lights and corners stay on after switched off
With the switch off the corner lights and the tail lights stay on.
Would my problem have a solution be near the same as this old post.I don't like the sound off a bigger fuse.
Quoted Message:
Originally posted by dmontzmax
Man mine were doing the exact opposite help me.All my dash lights corner lights and tail lights were going out so I replaced the fuse and then 2 minutes later they went out again.So I put a 15amp fuse in instead of a 10amp and havent had them go out in about a month now.Any suggestions?
Mr. Nismo
Needs non-Maxima Friends
This is probably the easiest and cheapest way to do it. Take out the corner lights and check the bulbs to make sure they are not making contact due to melting. Do the same for the rear taillights. Pull every bulb out! If one or more bulbs are stuck or hard to come out that means you have a short. Check the base of the bulb to see if the connectors are making contact due to melting. I would start with the taillights because it is most common to happen with the braking lights. Good Luck!!!! Let me know!!
Quoted Message:
Mr. Nismo
MaxLife17
Jun 27, 2019 01:37 PM
