Another clutch question
Before my car went into its comma, I was driving and the car drove fine, then the car just cut off , I would periodically try to start it without success and it's been sitting sence then. It's been about 2 years now and I finally got it to start. Well the things that worked before for some reason dont work now. For one thing, When I press my clutch in I get nothing. It just goes in without any effort. Before the car died I had no Clutch problems , but now that it sat for so long I have no pressure. What could this be?
Originally posted by Jeff92se
Looking from the front of the car, to the driver's side. Maybe the m/s is bad now. Try pumping it repeatedly and see what happens
I did that to. I pumped slow and fast, I removed the lines and pumped , I removed the slave cylinder and pumped and I dont have any leaks. I topped off my clutch fluid then pumped somemore. I dont get it, before it shut off I had no clutch problems, so it's hard for me to think its enternal
Okay now try bleeding it. hehe
Re: blood
Well open the bleeder valve on the slave and see if you can get the fluid to flow out when you push the pedal down.
I dont have any pressure, How bleedeth thow this
Sounds like a plan, Ill try tomorrow before I go to work. Ill have to get one of those Nobody helpin you bleeders, Because it aint nobody helpin me do it.
What if air comes out, would this build up pressure in the peddle??
If nothing comes out and you have fluid in the resovior(sp?), that means your master cylinder is probably dead or needs to be primed
Then the slave cylinder is probably all gunked up.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
