Questions on testing injectors....
Old Feb 4, 2003 | 12:25 PM
doomtoo's Avatar
How do you check the injectors resistance(a previous thread said "Injector resistance should be 10 - 14 ohms."?
And how can you clean off the injector ends?
(hopefully without taking much apart since I'm going to have to do all my work at a park)
"injector ends had gotten corroded and were not conducting electricity to the injectors "
Thanks-
Old Feb 4, 2003 | 02:18 PM
shoult's Avatar
Re: Questions on testing injectors....
It's just my 4.753 cents worth, but if you have the injectors out, send them to RC Engineering (http://www.rceng.com) and for $25/each they clean and balance them. Did that on my Supercharged MR2 and it made a world of difference.
Thanks-
Old Feb 4, 2003 | 02:37 PM
Jeff92se's Avatar
I'm needing a caw
I did 3 min of searching and found the answer. Why don't you? Maybe you will learn something along the way.
http://forums.maxima.org/search.php?...der=descending
You're actually lucky. Ben in the 4-gen forum would have told you to search and locked the thread.
Old Feb 4, 2003 | 04:41 PM
doomtoo's Avatar
Ok thanks. What did you use for your search? And is there any way to have it search for a phrase(exp: "spark plugs" doesn't work, even with quotes). And what does the "AND" do? It really narrows down the search, usually a little to far, but I'm guessing that if you don't have it, it will bring up posts with either word? (I had searched for "injectors" and "plug"[cause thats how I messed them up])
Mar 12, 2020 12:06 AM
jsmith24
Feb 1, 2016 12:35 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
