VTC rewire gone bad
VTC rewire gone bad
Hey guys, I hope someone can solve my riddle. I tried rewiring my VTC
today, but I had no success. I followed the directions exactly from
Craig's website. I checked the connections and there was current flowing through the VTC. When I grounded it and started the car, the car would turn over at all. There was no sound at all, just the dash lights coming on. I need help with this. Thanks
Re: VTC rewire gone bad
Try hitting your starter, it is a good chance it could of went out when you shut off your car, they do just go out. Mine did the same thing and it just so happened it went out after I took apart my dash, so I thought it was related to that, but it just failed at that time.
Definitly DO NOT hit your starter
The VE engine comes with a very good starter, it is a permanent magnet style starter, there are no brushes. Now if you have the VG engine then it would be okay to tap it a couple times to free up any sticking brushes.
You definitly dont wanna f-up the starter on your VE, it is very expensive.
Re: Definitly DO NOT hit your starter
Originally posted by Derek94SE
If you have VTC's, you have a VE, so try tapping it.
). Since when does haveing or not haveing VTC's got to do with the starter malfunctioning.
Re: Re: Definitly DO NOT hit your starter
Originally posted by dmontzmax
Well when mine would not start, I would hit the starter with my bar I carry in the trunk and it would fire up, sometimes I would have to hit it more than others, but I did that for about a week, until I could afford a new starter. I have had the car soo long that I have went through 2 starters and have done the same both times.
Your post indicates that you are an idiot (sorry but I had too
Your post indicates you can't read, as the original poster stated (quite clearly) that his starter began malfunctioning after he rewired the VTC's (ohh, there's that acronym again!). If the person has already quite clearly stated they have VTC's, you can safely assume they have the VE engine, and there's no need for the "if you have a VE" or "If you have a VG" stuff. Pretty simple to deduce.
I dont think he mentioned anything about the starter. Read more...eric, i have never replaced the solenoid. The starters last about 2-2.5 years, i start my car around 10-20 times per day.
If I came off sounding irate in my reply to eric, it wasn't my intent, my intent was simply to tell him what he had pointed out was exactly what the first person was asking about.
If your starters are only lasting 2-2.5 years you're either buying poorly reman'd PepBoy/AutoZone/AutoJunk starters or you have some other problem that is causing the starter to fail. Simply starting your car often won't cause it to fail in that short of a period.
eric, i have never replaced the solenoid. The starters last about 2-2.5 years, i start my car around 10-20 times per day.:)
Thanks dmontzmax, Try replacing the starter solenoid and clean all the power contacts with a wire brush. I can understand the great strain on your starter, but if the starter solenoid is not functioning properly then it will put a strain on the starter.
Re: Re: Re: Definitly DO NOT hit your starter
I'm sorry guys. I left out an important part. I couldn't get back on b/c my computer blew up. After i rewired the VTC the car wouldn't start, but when I take off the connection (ground) it would start like there was no problem in the first place. That's the big riddle.
Re: Re: Re: Re: Definitly DO NOT hit your starter
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
