JIC Helper Spring!
Old Feb 7, 2003 | 12:06 AM
MaxTuner's Avatar
JIC Helper Spring!
Can you put these helper springs on their coil-over system for the maximas?
http://www.jic-magic.com/
thx
Old Feb 7, 2003 | 01:01 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
maybe a more specific link would help
anyways, none of the coilover systems that im aware of from JIC uses the helper spring. im not complaining about noise. i have the FLTA2. i guess if you have no noise you prolly wouldnt need em
Old Feb 7, 2003 | 11:54 PM
JIC A33's Avatar
You should not require helper springs with the FLT-A2. The SF models it would be wise, but an additional cost.
peace.
Old Feb 8, 2003 | 11:00 AM
MAXIN's Avatar
any complaints at all??
Old Feb 8, 2003 | 05:25 PM
MaxTuner's Avatar
peace.
But does it fit on FLT-A2 systems? Does it increase ride comfort? maybe a little, I think!
Old Feb 9, 2003 | 08:11 AM
96BLUMAX's Avatar
I thought it said it helps cornering? Not ride quality.
Old Feb 9, 2003 | 12:36 PM
MaxTuner's Avatar
No, it's usually there to stop rattle/lose in the coil-over system. Cornering is depended on the spring rates. Another thing is, you can create a dual spring rate system on the coil-over system...but they are usually replacement for their RS series systems.
Old Feb 10, 2003 | 06:06 PM
JIC A33's Avatar
It will work and you're talking about a tender spring, not a helper spring, according to Ground Control's wording. A helper spring will hardly have a spring rate and is only there to retain the spring seat location. The tender spring is one which you can choose a lower spring rate to somewhat simulate that of a progressive spring. however, this will not allow you to lower the vehicle as much as you'd like. The thing to determine this is the spacing between the lower spring perch and the perch above the shock bracket.
so set your ideal ride height and take those measurements. once you have those measurements you'll need to determine the width of the mid perch and subtract that from the initial spacing figure you acquired between those perches. At that point you'll be able to interpolate the length of the tender spring you desire.
Peace, rishie
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
