fog lights out? wiring or bulbs?
i have a 1995 maxima and the both of the fog lights are out. is it the wiring of the bulbs or are the bulbs just out? if the bulbs are out what size bulb do i need to replace them? thanks
Re: fog lights out? wiring or bulbs?
Originally posted by WaarrEagle
Did they both go out together? If so then I doubt its the bulbs. Get a voltage meter and check for power. If not then you know to start checking fuses, relays, etc.
What WaarrEagle said. And stock '97 fogs take 55w H3's. Personally, I wouldn't go higher watt because of heat buildup in the small housing (cracked lens if they're hot and you hit water) and possibility of melting wires.
Dave
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
