rusty rotors - who has them?
I live in MA and every time it snows or rains overnight in the morning mu rotors are covered with rust (is it normal?), after driving around and braking the rust is scraped off, but not evenly on the rear rotors - the outside is cleared first and it takes some more braking to clear the whole area covered by the pad. I want to know how may people have this issue and how they deal with it? Also the brakes sqeal like hell before the rust is worn off, then they quiet down (also normal?).
I believe it's normal... but ask a chemistry buff... they should have a fun time explaining why it happens...
-Tom
PS... mine does the same thing, but once i start driving (actually braking) the thin coat of rust quickly disappears...
-Tom
Dave
Also - the rears take longer to clean because the fronts do about 75% of the braking - the rears just work enough to keep the back end behind the front end (except on the infamous Citation which had too much rear brake and spun all the time).
Dave
Dave
Originally posted by psing23
mine make some crazy noises everytime i brake like grinding and stuff... it bothers me to the point that the next $2000 i get im putting on brakes!! i will get a big brake kit and x-drilled / slotted roters in back...
what is the reason for getting rear slotted rotors instead of x-drilled all around?
Dave
Originally posted by wdave
Slotting might help with the noise as it gives the rust somewhere to escape as it's being ground off by the pad, it won't help though with the rust.
Dave
Dave
cross drills are mostly for the show...for us anyway since we'll never make our breaks to get that hot to a point where we really do those crossdrilled rotors....
plus...if you have crossdrilled/slotted rotors, the rotors will wear out alot faster than just a slotted ones..
Originally posted by NYC2SD
All cars have that rusty film on them. You can even see ut happening as the rain begins to fall. They thin film comes off with in the first 2 brake applications
Is it a problem then if not all the rust is removed from the rotors (the inner part of the rear rotors in my case) even after repeated braking?
Apr 16, 2020 05:15 AM
