Have a big problem with my horrid time....Take a look..HELP!
Ok, well my first attempt at the track last weekend yeilded me a 15.6sec time, granted this was in horrible conditions. I went back to the track today to find out i was still running where i shouldnt. My best time was a 15.01 and just shy of 92mph, WTF? I know i should be weeeell into the 14s with my Y-pipe alone. And yes, i can drive a 5sp very well, my friends stock 5sp (except for panel filter) ran a 15.1 today. Has anyone had any problems with their Y-pipe, more particularly the flex section collapsing?! I havent got to take a look at it yet...
eric
EDIT: Also, ive raced my friend in his 5sp, and i cant pull at all on his car (from a roll) like i should...
eric
Originally posted by Chris91SE
hmmm. i was hoping to see high 60 ft's or something. Everything on your slips look to be in order and consistent. is your car cali spec?
eric
Originally posted by Nealoc187
Your car is definately not making the power it should be. What elevation is your track at? Check that Y-pipe too.
eric
Originally posted by 99Maxima5sp
im in FL, so below or right at sea level pretty much... Yeah, thats my thoughts...gonna be checked in a coupla days...
eric
eric
My car at 500ft ran the times in my sig with just y-pipe and intake, so my bet is on a bad flex section.
My times went from 14.4 to 15's, once my y-pipe closed up almost completely.
If you have a Cattman, I would suspect thats the problem. That was with my 97 SE 5 speed, with JWT Intake, 2.5 inch custom exhaust, and the Cattman Y-Pipe.
Those times aren't too bad. And you improved almost a half second from last week, so you're going in the right direction.
Are you keeping the car in third gear at the end, or are you going to fourth? I know our cars lose power past 5.5K but I've gotten my best times leaving it in third.
Also, what's the condition of your spark plugs/fuel filter?
An intake wouldn't hurt either
Terry
Terry
Terry
Terry
ok... My best runs were by launching a tick over 2Gs with minimal spin and no bog, and leaving it in 3rd all the way, however i was at or past the redline every time (6600). My Y-pipe is from Budget exhaust. And yes, those are the times of a STOCK (exception of K&N panel filter) MAx, friends ran a 15.1-- with very similar 60fts...I went to Desoto Speedway in bradenton...also my tires were set at 19psi with my best run...
now my pipe is coming off wednesday for a meticulous check and i pray somethings wrong, it doesnt pull like it used to, perhaps a collasped flex section?
eric
eric
eric
eric
eric
eric
Have you dynoed your car at all?
the only advice i can give you is to work on your R/T. I say this because on one of your runs you have a 1.25~ reaction, i am sure that run could have been in the high 14's with a better R/T.
R/T has absolutely nothing to do with ET!!!
well obviously RTs mean squat, you can sit there for 25minutes and still run a 14.5
, all they determine is your REACTION TIME from the moment the lights turns green and you move...And when i wanna get a kick *** RT, i can, got a .522 last week
anyways, 19psi is a bit low, but they provided the best and worst grip of the day. You have to remember, first im running on wrong sized tires, its what came from the dealer, small *** 205/55-16s, and they have a 540treadwear rating, their hard as rocks compared to my last tires on my old car (Yokos AVS ES100, great tires!) I tried lowering the pressure to about 25, they built up to around 28, lowered to about 21.5, and the built up to 24.5, so i just decided to go real low (19PSI), and low and behold, i had my best run IMMEDIATELY after that, a 15.01.
Also, i had my stereo removed
, and i guestimate it weighs 60-70 (?) lbs, not to heavy. I mean i tried everything to get a better time, even removed my filter, lol, that yieled a .1 SLOWER time, consistently....
And quicksilver- theres no way it can really be my exhuast itself, ive noticed the downfall in power AFTER i installed the y-pipe. When i first installed it, i couldnt grip in first, i could floor it at any time in first and i would lose control a bit from lack of grip, yeah that doesnt happen now. I dont get that wonderful pull, all i get now is a rediculous rasping noise thats getting worse and worse, almost sounds like a damn air leak now coupled with ratting. I know its got to to with that damn y-pipe and i hope it does...
ill keep you guys posted since its getting looked at real soon
Oh yeah, also, has anyone had their Cat prematurely clog after installing the Y-pipe, since its letting more **** go to the actual cat. Just curious...
And another question, i noticed that when i was crossing the line on one of my runs, i saw the speedo well over 95ish mph, yet my slip said 91 and change, wtf? are our speedos that far off at that high of speed? I remember reading something that one of the org members said, saying that the max speedo is 3mph off??
eric
, and i guestimate it weighs 60-70 (?) lbs, not to heavy. I mean i tried everything to get a better time, even removed my filter, lol, that yieled a .1 SLOWER time, consistently....And quicksilver- theres no way it can really be my exhuast itself, ive noticed the downfall in power AFTER i installed the y-pipe. When i first installed it, i couldnt grip in first, i could floor it at any time in first and i would lose control a bit from lack of grip, yeah that doesnt happen now. I dont get that wonderful pull, all i get now is a rediculous rasping noise thats getting worse and worse, almost sounds like a damn air leak now coupled with ratting. I know its got to to with that damn y-pipe and i hope it does...
eric
Your 1/4 mile trap speed is averaged over the last 60' (I'm pretty sure it's 60 feet) so the speed on your slip will be slower than the speed on your speedometer. Plus the speedo is probably at least 2-3 mph fast at those speeds.
Go get your car dynoed and see what it's putting down to the wheels. I think that's the best thing you can do at this point. Either it's putting the power down or it isn't and there's something wrong, and a dyno will help to determine that.
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
