help my pass. side blinker wont work
Old Feb 27, 2003 | 03:57 PM
darrick's Avatar
Dallas Nissan Enthusiast
Help guys I have tryed 4 diffrent bulbs and I checked the wire today with a test light and no jucie is there.is there a fuseable link or fuse some where i should check?
Old Feb 27, 2003 | 06:13 PM
TitleistPrto's Avatar
Did you check the turn signal fuse?
Old Feb 27, 2003 | 06:14 PM
darrick's Avatar
is this in the dash?
and would the other turn signals work if it was the fuse?just asking i really dont know
Old Feb 27, 2003 | 06:19 PM
the fuse box is to the left of the steering wheel under the dash, there is fuse map to tell you which one is the signal. Niether turn signal would work if the fuse is out.
Old Feb 27, 2003 | 06:28 PM
Kashoggio's Avatar
If the other side blinker works, then its not your fuse.
You should go to the blinker stalk and test for current going to that blinker. The best thing you should do is get a wiring diagram for the blinkers and you will be able to figure where to test the circuit
Old Feb 27, 2003 | 06:30 PM
darrick's Avatar
yeah that what i was thinking
what else could it be ?when you turn on the right blinker it blinks fast like the bulb is out. strange, I cant fig this out...ok were can i find a skimatic?
Old Feb 28, 2003 | 06:03 PM
darrick's Avatar
bump
anybody?
Old Feb 28, 2003 | 06:26 PM
happyricefob's Avatar
V^___^V
try this but i donno...
change to higher voltage (such as 15A or 20A) maybe it'll work... i did this setup to my tail, it was originally 7.5A and it kept blowing my bulbs and my fuses... i changed it to 20A and now it's workin fine...
give it a shot =)
Old Feb 28, 2003 | 06:41 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: yeah that what i was thinking
IT blink fast because the bulb is out, its giving you a warning so you know why its blinking fast. Are you using after market bulbs?
Old Feb 28, 2003 | 07:14 PM
darrick's Avatar
Re: Re: yeah that what i was thinking
I have tryed apc,reg autzone bulbs,polorg,and even tryed putting the bulb that was in there when i got the car nothing works,this is killing me cause it was working before i put the clears in.
Old Feb 28, 2003 | 07:21 PM
CystumMax's Avatar
Re: Re: Re: yeah that what i was thinking
Ok i see, i had similar problem, but this was with indoor lights thats on the door. i replace the bulb with a after market bulb. and it stop working. and i did anything i could. i took multimeter to the car and check for voltage nothing. i thought may be i burned the wire or something. i had to take to dealer. they replaced a moduale in the door. which brings power to the light. i am not saying this is your case. but check it with multimeter. somethimes you could get a signal reading from it. if you dont get anything. there has to be with some type of relay or module box. good luck to you.....
Old Mar 1, 2003 | 06:55 AM
darrick's Avatar
ah
bump
Old Mar 1, 2003 | 10:27 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: help my pass. side blinker wont work
kick it...kick it realllllly hard.
Old Mar 1, 2003 | 01:57 PM
darrick's Avatar
Re: Re: help my pass. side blinker wont work
lol that worked thanks man!!!!!!!!!!!
Old Mar 2, 2003 | 03:47 AM
Re: Re: Re: help my pass. side blinker wont work
always does..
Old Mar 2, 2003 | 05:18 AM
Cumalittle
did it really??? cuz i had that happen to meeh once...was driving meeh nutz...wat happen was the contact on the socket was sitting flat when it should have been sticking out a lil bit to make contact w/ the nipple on the bulb...look at ur socket...and take something small and non-conductive and pull the tab out some...
Old Mar 2, 2003 | 07:14 AM
darrick's Avatar
Re: Re: Re: Re: help my pass. side blinker wont work
yeah that what really happened (it bent down),but it was funny to say it kicked it .he,he
jerrod99_se-l
Aug 27, 2015 08:27 PM
Max8
Aug 20, 2015 07:20 PM
shaunkey1
Aug 18, 2015 10:09 PM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
