Broke the head of a bolt?
Old Mar 8, 2003 | 06:41 PM
Virus's Avatar
Like a dummy I tightened the bolt for the FrankenCar support bracket on the strut tower. Any ideas on how to remove it?
Old Mar 8, 2003 | 07:10 PM
MiniRX7's Avatar
Oh my..
I thought i was the only retard that did that too.. It was right on the strut tower assembly..
Let me guess.. u used the stock bolt to hold the bracket, kept on turning and it bent and snapped the head off.
What i did was pay a mechanic $40CDN, and bought a new bolt from nissan (those bolts are $10 cdn)... and he drilled out the old and cut the new OE bolt down to size. Now everything fits perfect.
No worries..
www.pbase.com/minirx7
click on 2003
ED
Old Mar 8, 2003 | 07:23 PM
ajahearn's Avatar
drilling out
drilling out the old bolt is typically what you do. You use a steel cutting bit that is smaller than the original bolt. You can try a bolt of the same size fed in behind the first. Hope this helps.
Old Mar 8, 2003 | 07:28 PM
Virus's Avatar
Thanks. I'm not sure if I should attempt it myself or pay someone. I'm scared like hell to screw the threads up.
I used the original bolt which of course is way too long for that particular hole. I put 4 washers on the top. It really didn't take much to break it off. It was turning pretty easily.
Old Mar 8, 2003 | 11:46 PM
SG01MaxSE's Avatar
A friend of mine actually used some kind of epoxy to put a snapped bolt back together. It worked long enough for him to GENTLY unscrew the bolt. It wasn't a very heavily torqued bolt though.
On second thought... you'll probably have to drill it out.
Definitely, let someone do it who has done it before. Otherwise, you might end up with a snapped bolt AND unusable threads in the bolt hole!
Old Mar 9, 2003 | 05:09 AM
Matticus's Avatar
Basically drill the bolt out, or use a screw out tool, depending on how wide the bolt is. Even if you do mess the threads up, it isn't a big deal, just re-tap them and you're set.
Old Mar 9, 2003 | 07:11 AM
tbirdrob's Avatar
If you have some small part of the bolt sticking out, you can use this tool:
http://www.sears.com/sr/product/summ...id=00904458000
If not--pay somebody to do it for you!
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
