I'm gettin CEL 0505 "No Failure Recorded/Detected"??
I am getting code 0505 which means "No Failure Recorded/Detected". If there is no failure why the light is on?
OT: When is the search function going to be enabled again?
Re: I'm gettin CEL 0505 "No Failure Recorded/Detected"??
http://forums.maxima.org/showthread....hreadid=104931
run the test couple times. and count it over and over. you might miss count something?
I am positve that is 0505. I also followed the instructions to get the trouble codes from the sticky
Originally posted by CystumMax
Ok disconnect your battery and waite 5 min then reconnect it back. and start the car. see if the light comes on. if it does run the test over again.
Well...I did what u said and the CEL went away. I checked for codes anyways and still got 0505. Weird....at least the light is off now.
I think normally you should get code like that from the ECU. i could be wrong. hopefully more expert could answer this question.
jmlee44
Oct 2, 2022 02:13 PM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
