ran the 1/4 mile today
I have a 97 5-speed with a budget y and frankencar intake. I took it to the strip today and turned up 15.5 and a 15.6 backed by another 15.6. I am a little disappointed as i thought my car would do better than that. My 60 foot times were 2.25 and 2.26 and my mph was 88-89. I thought i would run a 14.8-15.2, Maybe its the bad Knock Sensor?
Re: ran the 1/4 mile today
Originally posted by CoasTek240
hey those are decent times... whats a franken car intake?
Do you use premium gas? When was the last time your oil was changed? Spark plugs? What was the weather? Most '97+ don't have the knock sensor problem but its definitely worth looking into.
-Cyrus
seems like you're driving damn good judging by the launch, but your max isnt making as much power as it should be.
trap speed is low - indicator of lower than normal power, esp for intake/ypipe.
check your engine codes for knock sensor (won't have CEL), spark plugs, ignition coils, fuel injectors, clean throttle body. something is holding you back from making a lot more power.
once you find it...you're definitely in the 14's
60'2.255
330 6.491
1/8 9.996
mph 70.29
60'2.255
330 6.491
1/8 9.996
mph 70.29
Originally posted by 1SikMax
Wow, that is what I usually run in the 1/8th. That's with everything stock and 80 degrees outside and 80% humidity. I hope it's just your knock sensor.
bill4max, switch up that knock sensor for a good one, and im pretty sure you will see a 0.8 second improvement
R/t .622
60' 2.259
330 6.539
1/8 10.048
mph 70.18
1/4 15.655
mph 88.31
And
R/T .795
60'2.255
330 6.491
1/8 9.996
mph 70.29
1/4 15.596
mph 88.62
R/t .622
60' 2.259
330 6.539
1/8 10.048
mph 70.18
1/4 15.655
mph 88.31
And
R/T .795
60'2.255
330 6.491
1/8 9.996
mph 70.29
1/4 15.596
mph 88.62
well my ks is bad definetlly as code 0304 comes up by itself also i have checked it and there is no resistence meaning an open circuit. I dont get it though because i have good 60 foot times. Do you think more is wrong than just the knock sensor?
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
