I dynoed yesterday
Old Mar 17, 2003 | 10:33 AM
jdmmax's Avatar
I dynoed yesterday
hi all
i got a chance to dyno my car yesterday.
here are the charts
http://fastforward.lchu.net/church%20data/FSC-FWT.JPG
torque and hp
http://fastforward.lchu.net/church%20data/FSC-FWT2.JPG
torque and a/f
http://fastforward.lchu.net/church%20data/FSC-VBP.JPG
boost
the green line is 2nd gear pull
the red line is 3rd gear pull
numbers are from 4000 rpm and up becasue the trans will keep down shifting or something like that.
it was also a chassis dyno. they took my wheels off to do the dyno.
what would be the typical difference between a chassis dyno and a wheel dyno.
i a little worried about my a/f in the top end i start to lean out.
they were speculating that my fuel injectors were maxing out. is this the case or do i need to throw the 8:1 fuel disk in.
give me some advice guys i want to be in the 300hp range.
thanks Frank
Old Mar 17, 2003 | 10:39 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Looks like they cut you short on a couple hundred RPMs.
11.4 psi?!?! What pulley are you running?
Old Mar 17, 2003 | 10:42 AM
jdmmax's Avatar
3.125 pulley
what sould they have started the dyno at. cause it was wierd there were a few pulls where my peak boost was like 5 psi like it wasn't boosting but the rpms went up. it was kind of weird.
Old Mar 17, 2003 | 10:46 AM
ejj's Avatar
ejj
I think Kev means up top. The charts stop at 61XX. They should chart to the redline.
Old Mar 17, 2003 | 10:49 AM
jdmmax's Avatar
ohhhhhhh i see. awwwww d@mn it
oh well
Old Mar 17, 2003 | 10:52 AM
Stephen Max's Avatar
3.125 pulley
That would happen if they didn't have the throttle wide open. Not sure why they would do a partial throttle run, though, except maybe for prep type stuff.
Old Mar 17, 2003 | 11:02 AM
Y2KevSE's Avatar
3.125 pulley
Redline is 6650, so have them take it all the way up.
Do you have the graphs of the 5 psi runs? If they were going WOT, were the hp/tq numbers the same?
Old Mar 17, 2003 | 11:07 AM
jdmmax's Avatar
nope didn't get the graphs on those partial runs.
i think those were the 2nd gear pulls i think when he would gas it to much it would down **** into 1st or something to that effect.
should i worry about my a/f ratio though????
Old Mar 17, 2003 | 11:21 AM
WizzaMax's Avatar
So it all means this:
264.6 max HP
233.5 ft/lbs max torque
AFR 12.9
11 lbs psi
impressive...no we need to take it to the track again...
any luck on the S-AFC?
Old Mar 17, 2003 | 11:29 AM
Y2KevSE's Avatar
Looks like everyone has been running lean recently.
8:1 disc works better with the 3.125 pulley.
Old Mar 17, 2003 | 11:34 AM
jdmmax's Avatar
do i have to worry about locking up my fuel injectors????? imgetting close to 90 psi on the 6:1 fuel disk.
Old Mar 17, 2003 | 11:43 AM
Y2KevSE's Avatar
You should be getting around 83.5 psi at peak boost with 6:1. Some people worry about their pressure going above 90 they have a right to be. 8:1 will increase pressure to about 105.5 psi, so you may feel like you're in a lose-lose situation.
1) run lean
OR
2) run a high amount of pressure
Both options can damage things.
Old Mar 17, 2003 | 11:47 AM
1) run lean
OR
Time for 370cc/min injectors.
Old Mar 17, 2003 | 11:49 AM
Y2KevSE's Avatar
OK...
3) spend more money
Old Mar 17, 2003 | 11:51 AM
jdmmax's Avatar
thats what a couple of the guys there were saying. would i be able to use a s afc to control 370cc injectors???
or would i need a stand alone which is $$$$$$$$$$$$$$$$$!?!?!?!?!!?
Old Mar 17, 2003 | 11:59 AM
JAY25's Avatar
lower the base fuel pressure to 20 PSI and drop a 4:1 disc, thats what Mardigrasmax has done. Thats all I will do. Also since the SAFC can lean the fuel mixture more power to it because that will be my project hopefully next year and a possibly a 3.125 pulley. 11.5-12PSI here I come.
Old Mar 17, 2003 | 12:06 PM
jdmmax's Avatar
was mardi gras base psi 20 at idle????
Old Mar 17, 2003 | 12:07 PM
Mardigrasmax was running 370c/min injectors with a stock ECU and a fields afc. He's using a G-force ECU now. An s-afc ought to work just fine. You'll have to experiment with fpr disk size.
http://forums.maxima.org/showthread....ighlight=370cc
Old Mar 17, 2003 | 12:28 PM
jdmmax's Avatar
does anyone know if the sr20det injectors and the tt z injectors are the same or not?????
tarun900
19
Dec 20, 2021 06:57 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Junebug1701
Sep 25, 2015 01:54 PM
foodmanry
Sep 24, 2015 12:02 PM
