Engine Swap
Old Jan 14, 2001 | 01:02 PM
87/01 Maxima
I have an 87 SE with a bad Engine. Have oppurtunity to purchase 90 SE for parts. Can I make this Engine fit 87?
Old Jan 14, 2001 | 01:14 PM
Sith's Avatar
there the same engine with different manifolds, so some things are placed in different positions.
But if your just talking about swapping the block it should be fairly easy.
Old Jan 14, 2001 | 01:19 PM
SkyMax's Avatar
Where's Nismo87SE when you need him??
He'll know for sure what you can do with the swap.
Old Jan 14, 2001 | 01:50 PM
brubenstein's Avatar
There's the same, and then there's direct replacement. Aside from the intake there are some number of other differences. For instance, the oil filter is in different places. The key thing to find out is if the motor mounts are the same: if they are the newer motor will bolt in. I am not sure about all of the different engine sensors. If the sensors are different and/or wired different you might need the newer wiring harness and ECU. Another possibility would be to use the old intake, injectors, sensors, etc.
Sorry I can only point out some ot the issues, and not give a difinitive answer.
Old Jan 14, 2001 | 01:54 PM
Jon Little's Avatar
97 in a 90
is it possible to put a 97 engine in a 90? without many modificatios
Old Jan 14, 2001 | 02:57 PM
SkyMax's Avatar
Re: 97 in a 90
LOL... stop dreaming
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
