Window Vent Visors
Re: Window Vent Visors
Originally posted by illmaxima
Have any of you removed window vent visors from ya max, and if so whats the easiest way to get them off the car?
and if you are not...then just yank them bad boys off and scrape of the double stick tape (CAREFULLY) using the blade....you can spray WD40 on the tape to loosen it up and use the goo gone to remove the sticky residue
good luck
I slowly pulled mine off and cleaned the window trim with goof-off
If I ver decide to put them back on (which I probably wont) I'll just remove the old tape and get new 3M double stick tape.
