A/C problems
Old Mar 20, 2003 | 01:05 PM
tampamax's Avatar
A/C problems
The a/c in my car doesn't seem to be cooling quite like it used to. The wierd thing is that when I switch to pull in air from the outside(vent mode) there is is damn near a waterfall that starts dripping down onto what would be the passenger foot area. It is coming from some place behind the glovebox. This is not a drop or two, this water flow could fill a 6oz. cup in about 45 min to an hour. What gives?
Old Mar 20, 2003 | 01:16 PM
max...to the ma's Avatar
sounds like a leak or hole in ur ventilation system. take it to the dealer
Old Mar 20, 2003 | 01:23 PM
Nismo's Avatar
either the evaporator or lines are leaking or the condensation drain is clogged with leaves and junk that so much condensation builds up and finally pours out. the drain is located in the passanger fender well.
Old Mar 20, 2003 | 03:07 PM
tampamax's Avatar
Thanks i'll check the drain, um where can i find that. I know i know the passenger fender well, but where exactly? Thanks for your imput.
Old Mar 20, 2003 | 10:47 PM
Nismo's Avatar
I personally havent looked at it myself on the max but its a tube that hangs down up in the passanger fenderwell. try sticking a rod up in it to clear out any blockage. I think that you have a coolant leak somewhere since you stated that its not cold anymore. Possibly a leak somewhere close to the evaporator which is a big headache and expensive fix since its located in the dash
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
