Don't Turn Corner Bulbs Around For Brighter Lights
A few weeks ago someone on this list gave instructions to cut off one of the pins on the corner lamps and install 180 degrees from normal position to make the corners brighter. This, seeming much simpler (and easily reversed) than the re-wire option, made me give it a try. Yes the bulbs are brighter, but after a couple of weeks the chrome reflective surface has turned all black. The corner lamps looked smoked. I pulled them back out and it appears that quite a bit of heat was generated. I have changed them back to the stock configuration. Has anyone else had this problem? Do you have the same problem if you rewire them? They are really dull due to the fact the reflectors are now shot!
I'm in between on this one. I've had this setup for very long, and by all means my reflector housing hasn't turned black. But, there is a tiny hole which is black but is not visible unless looked for very carefully through the plastic housing.
So like the others, I have also had no problems, but I still worry sometimes.
If you are worried about heat, I would do a search on google for some white 1157 LEDs, they should be brighter and give off nearly no heat. I currently have Polarg 1157s installed with the nub sanded off but as soon as I get some extra cash im going to try LEDs. The downside is they cost like 20$ each, but then again they pretty much last forever. (100,000 hour warranty or something like that)
I did the nub thing and no problems yet. Did you paint your bulbs? Had you handled them a lot with your hands? The oil in your skin or something on your hands might have burned off. You might also have some type of leak or something in the housing. Has your car been wrecked? If it has aftermarket (not nissan) corners, the insides might have gone bad somehow? What brand bulbs are you using?
Just a few things to think about.
Originally posted by WhiteMax96
What is this mod of cutting the ***? What is a ***? Pics of that mod and explaination would be very appreciated.
btw I have mine almost 2 years with no problems yet using both stock and polarg bulbs
The car has not been wrecked, corners are factory Nissan and show no signs of leaking. I don't know if the bulbs have ever been replaced (2nd owner) but they are just standard 1157 bulbs. Both sides are bad with the drivers side slightly darker than the passenger side. I noticed it when walking towards the car a few days ago. They look like the lenses are smoked. Upon taking it apart, I can see that the chrome reflective surface is almost entirely black now. Looks like a heat problem. Anyone have a couple of factory corners laying around they want to get rid of?
Re: Whats the Site
Originally posted by T2CTeamShift
Where does it teach you how to do this, I wanna join the club!
Re: Don't Turn Corner Bulbs Around For Brighter Lights
Example i have heard from 3 different people that you could change the lights for power window on 99 maxima and need to get the radio shack one 5 v bulb 25000mvz something like that and change them. but 99 maxima you can't do it. i recommend you get xenon bulb for the corner lights. thats what i have on mine.
97-99
http://home.earthlink.net/~maxfaq/el....htm#97corners
95-96
no soildering.. just switch the positive wires around
95-96
King_Ten_Ahead
Sep 30, 2015 04:27 PM
bc992164
Aug 26, 2015 12:19 PM
220k+ A32
Aug 17, 2015 03:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
me too
