Stillen Oil Cooler question
Bill, these are referring to permacool, and I am not certain that Permacool's setup and Stillen's setup are similiar in that respect. I too searched
and didn't come up with a answer specifically relating to the Stillen kit, with their "no-name" filter sandwich adapter, and unidentifiable cooler.
Anyone else?
and didn't come up with a answer specifically relating to the Stillen kit, with their "no-name" filter sandwich adapter, and unidentifiable cooler.Anyone else?
Originally posted by Y2KevSE
I used -8 lines... -8 120 degree bend fittings off the sandwich adapter (probably 1/2 NPT)...
You need to find out what the fittings are for the cooler.
Originally posted by bill99gxe
Perhaps $tillen sucks or is overpriced and everyone went with Perma-cool?
In reality, Keving could answer your question in 2 seconds but is choosing not to right now.
by StillenI don't think Keving has the answers, but maybe he should give me the link to his Permacool kit so I can get that instead.
Mocal 180 degree F thermostat build into the sandwich adapter.
Originally posted by delio
jOo got links? gimme more info. I need to order this stuff ASAP. What fittings and stuff did you get for the cooler? I think I am going to go with the dual cooler and do the PS as well, makes things a little cleaner under there.
http://www.racerpartswholesale.com/mocal.htm
Excerpt from http://forums.maxima.org/showthread.php?threadid=187943
Originally posted by JAY25
wish I was in Cali to work on that beast and get it done. My car was down for 2.5 weeks I cant picture my car been down that long.
By the way where did you get the fittings to fit your Oil cooler? I would like to do that with the stainless steel lines, looks very neat and no mess, These rubber hoses just aint cutting it no more.
4 FCM2008 -8AN flare 1/2 NPT
2 FCM1013 -8AN hose ends (you may want to locate a good spot for the cooler before buying these)
2 FCM1043 -8AN 120 degree hose ends
PS? That is probably an overkill since you already have aluminum lines for it.
I would like to do everything in SS, but I need to mail order everything since I don't have ANY decent tuner shops around here.
Aluminum? Huh? Mine are rubber, going to the aluminum U shaped tube, coming back out as rubber. I have the hard alumium lines going into the Pump if I am correct, but not going to the cooler.
Gotcha... you want to go all out bling bling and do SS lines for everything.
I thought about but my hands/fingers said no from being pricked so many times.
The PS hoses look to be -6... can't use hose ends on the plastic reservoir but you can use straight ends on the new threaded cooler (or 90 degree hose ends... depends how you're mounting it).
Yeah, I was talking about the aluminum U tube.
I have the issue now with the Oil Press guage, the SS line for it rattles to high hell. I am going to buy stock in a zip tie company.
Hmmmm
Did you use a B&M tranny cooler or did you buy a kit and throw all the junk out?
The Stillen & Permacool oil coolers help to keep your oil cool. Hope this helps!!!
What the heck is all this about anyway!!! What are you up to?!?!? PM me...
Deac
Re: Hmmmm
Originally posted by Deac
Del,
Deac
Del,
Deac
I have had the stillen cooler for over 2 years now
I am looking to go to a dual pass cooler to clean up the routing of the lines, and I want to get away from the rubber lines to Stainless steel lines for some more show appeal (Bling Bling) So I am considering switching from the Stillen kit that I already have to a different, obviously custom setup and I need to pester Keving for some more info.
Bought a B&M cooler and boxed the PermaCool kit.
hahahaha
is it a tranny cooler or specifically for motor oil? does it even matter? I want to be blingin like you Keving
OK I know I am becoming a PITA... where did you get it...
hahahaha
hahahaha
sigh..
www.jegs.com
Originally posted by redmaxpa007
how did you ever install your stuff yourself???
sigh..
www.jegs.com
sigh..
www.jegs.com
Thanks Pinky
Re: Re: Hmmmm
D,
D,
Deac
There's a polished one on that site? No but there is in Kevina's car, so either he bought it that way or paid for the bling bling, that's what I need to know.
Thanks Pinky
Thanks Pinky
130-70265 Supercooler 15,000 GVW (11''x 4.5'' x 1.5''), Polished Aluminum, (2)
Yes, there is a polished one on the site... didn't pay bling bling for it.
Took you long enough... your wrist still limp? err I mean sprained
http://forums.maxima.org/showthread....ighlight=70265
Get the 70255 if you don't want to custom do the fittings......
I'm getting vuja de:
kjlouis
Oct 3, 2015 05:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
oints to del's avatar:
