urgent!!! need to know where to connect the air fuel ratio gauge...
i am trying to connect the air fuel ratio gauge and dont know where to connect the o2 wire... i have a 2001 engine with the 4 plugs instead of the 2 plugs for the 2000's
Re: urgent!!! need to know where to connect the air fuel ratio gauge...
You can figure out which is the front/rear bank by back probing the ECU pins and doing a continuity test with a volt meter to the O2-plug under the hood that connects to the FRONT 02-sensor. You can then just tap the 02-plug wire you find. Either place will work, but the ECU worked fine on a 4th gen..
Let me know, but the ECU is a bit of a bish to reach/tap.
Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
Originally posted by IceY2K1
If your willing to tap the wires at the ECU, I can give you which wires, but I'm not sure which is the front/rear(bank 1 vs. bank 2) bank? Do you have a FAX number?
thanks
Re: Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
my friend was trying to tap it to the ecu, but he couldnt find the o2 line..... please give me info about where the o2 is on the ecu
thanks
thanks
If not, you need a FAX number, because withOUT the diagram you'll never find it.
Re: Re: Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
Do you have a ESM/FSM?
thanks for helping me...
but i guess the fax machine is outta ink...
i ll try to figure it out...
thanks a lot for your help/....
you dont have it on a computer??
a33, if you want to borrow my FSM... let me know...
My friend's shop; he's actually got my friend's 300zx right now. Needs some engine work; AMS f'ed it up and cyl 3 has deadly low compression.
jer, where did u get your charger installed????
