urgent!!! need to know where to connect the air fuel ratio gauge...
Old Mar 31, 2003 | 04:16 PM
a33's Avatar
a33
i am trying to connect the air fuel ratio gauge and dont know where to connect the o2 wire... i have a 2001 engine with the 4 plugs instead of the 2 plugs for the 2000's
Old Mar 31, 2003 | 07:59 PM
Chris Gregg's Avatar
Get Off My Lawn
Re: urgent!!! need to know where to connect the air fuel ratio gauge...
I suggest that you buy and install the Auto Meter O2 sensor. I've heard a lot of complaints and had problems myself trying to tap into the stock sensor. You can try, then sauder the wire back if there's problems.
Old Apr 1, 2003 | 03:15 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If your willing to tap the wires at the ECU, I can give you which wires, but I'm not sure which is the front/rear(bank 1 vs. bank 2) bank? Do you have a FAX number?
You can figure out which is the front/rear bank by back probing the ECU pins and doing a continuity test with a volt meter to the O2-plug under the hood that connects to the FRONT 02-sensor. You can then just tap the 02-plug wire you find. Either place will work, but the ECU worked fine on a 4th gen..
Let me know, but the ECU is a bit of a bish to reach/tap.
Old Apr 1, 2003 | 03:22 PM
a33's Avatar
a33
Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
my friend was trying to tap it to the ecu, but he couldnt find the o2 line..... please give me info about where the o2 is on the ecu
thanks
Old Apr 1, 2003 | 03:29 PM
IceY2K1's Avatar
Re: Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
thanks
Do you have a ESM/FSM?
If not, you need a FAX number, because withOUT the diagram you'll never find it.
Old Apr 1, 2003 | 03:31 PM
a33's Avatar
a33
Re: Re: Re: Re: urgent!!! need to know where to connect the air fuel ratio gauge...
Old Apr 1, 2003 | 03:34 PM
IceY2K1's Avatar
I'd delete that.
You don't want people sending you crap.
I'll send it right now.
Old Apr 1, 2003 | 03:39 PM
a33's Avatar
a33
thanks for helping me...
but i guess the fax machine is outta ink...
i ll try to figure it out...
thanks a lot for your help/....
you dont have it on a computer??
Old Apr 1, 2003 | 03:45 PM
IceY2K1's Avatar
Yeah, PM me your email address and I'll attach a word doc.
Old Apr 1, 2003 | 09:41 PM
Jer's Avatar
Jer
a33, if you want to borrow my FSM... let me know...
Old Apr 2, 2003 | 07:09 PM
a33's Avatar
a33
jer, where did u get your charger installed????
Old Apr 2, 2003 | 09:32 PM
Jer's Avatar
Jer
My friend's shop; he's actually got my friend's 300zx right now. Needs some engine work; AMS f'ed it up and cyl 3 has deadly low compression.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
