is there a tape or "wrap" for squeaky lowering springs?
i heard of a product that is a tape material that can be wrapped around springs if evidence of sweaking is present. is this true, and, if so, what is a good brand to use? i have suspension technologies lowering springs with tokico struts. they work great, but make a creaking sound over bumps.
Re: is there a tape or "wrap" for squeaky lowering springs?
sweaking is not so bad. it just comes up sometimes over speed breaks or holes. i'll ask this dude at the skating rink again what he meant. then i'll post it here to clear this up.
Re: "wrap" for squeaky lowering springs?
suspension
Originally posted by jkmay01
Have you checked your strut mounts? Sometimes you can get noise from there also? What about the strut bump stops? That can add more bumping and noise if bad? Check those out!!
Re: suspension
thank you. i will check those. that sounds more serious.
This was when i first was starting out with the mechanics thing!!! LOL But that should help out on the smoothness of the ride, I didn't read to see what type of lowering springs you went with? As you already know some spings are noiser than others, like Tokico compared to intrax
Re: suspension
Summitracing.com sellings a spring wrap.
if you want to do it a little cheaper, you can always try this:
http://www.vqpower.com/v2/modules.ph...howpage&pid=11
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
