Oil pressure or temp?
Old Apr 19, 2003 | 11:05 PM
Lonely Driver's Avatar
Which is more important to monitor on a boosted vehicle?
Old Apr 20, 2003 | 07:35 AM
on_alert's Avatar
They are both kinda important.
Temp: If you put it right after the charger, you can see if the oil is nearing coking temperature.
Pressure: You will blow your charger with inadequate oil pressure, and can tell if there is a oil line problem because the oil pressure will be higher.
-ctn
Old Apr 27, 2003 | 05:03 PM
CandiMan's Avatar
Say Candyman 5 times
Both would be nice
But if I had to pick one, I'll say pressure. Pressure is the life source for engines, no/low pressures (along with others) eqaul bad things. I've heard in the pass that the oil temp is more accurate method of monitoring the eng temp when compared to coolant. How true is that, I'll probably never get to find out.
Old Apr 28, 2003 | 06:53 AM
ejj's Avatar
ejj
Re: Both would be nice
I think its a safer way to measure engine temp. My coolant (according to the stock guage) get up to "normal" temperature well before my oil is up to "normal" temperature.
I'm pretty sure that's why Stillen recommends that you don't boost for 5 minutes after the coolant is up to normal temp. Gives your oil a chance to catch up.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
