Oil feed line
Old Apr 20, 2003 | 08:24 PM
delio's Avatar
Oil feed line
Anyone remember how long it is on the SC setup?
Old Apr 20, 2003 | 09:43 PM
BigDogJonx's Avatar
Re: Oil feed line
I think the braided line was 4ft long. maybe 5ft.
Dixit
Old Apr 21, 2003 | 07:07 AM
delio's Avatar
Re: Re: Oil feed line
Dixit
RELLLLP!!! Anyone got a more definitive answer?
Thanks for the effort BigDog, I should have just pulled it out and measured it. Stoopid Delio
Old Apr 21, 2003 | 07:10 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
It's long.
Old Apr 21, 2003 | 07:37 AM
delio's Avatar
Originally posted by Y2KevSE
It's long.
Thanks for the insightful and informative post Keving
Old Apr 21, 2003 | 07:59 AM
[maxi-overdose]'s Avatar
Re: Re: Re: Oil feed line
no need to pull it out....get a wire or something and match it to the oil feed line. take out the wire and measure that.
Old Apr 21, 2003 | 08:08 AM
delio's Avatar
Re: Re: Re: Re: Oil feed line
Well if I am going to replace it, might as well pull it out now.
Old Apr 21, 2003 | 08:17 AM
Re: Re: Re: Re: Re: Oil feed line
what happpened to your line?
Old Apr 21, 2003 | 08:48 AM
delio's Avatar
Re: Re: Re: Re: Re: Re: Oil feed line
Ummm a chunk of the braiding is missing... I don't think it's leaking, but those are chances I am not willing to take.
Old Apr 21, 2003 | 10:22 AM
Y2KevSE's Avatar
Bad install. You should kick the installer in the
Old Apr 21, 2003 | 10:56 AM
delio's Avatar
Damn that would hurt, and I am not into S&M
Old Apr 21, 2003 | 10:58 AM
Jeff92se's Avatar
I'm needing a caw
You guys are doing your own braided ss lines right? ie.. cutting the line and installing the end fittings? How do you guys do that? Would be much easier than the hard line bending kit I was thinking of buying from Eastern tools.
Old Apr 21, 2003 | 12:39 PM
Y2KevSE's Avatar
Not sure what D is doing. If you want instructions on how to make SS lines, PM ejj (or delio). I gave him, ejj, a detailed write-up of how I did mine.
Old Apr 21, 2003 | 12:51 PM
ejj's Avatar
ejj
I already looked...I cleaned out my PM box a while back and lost them. However, I think I emailed to delio, so they should be in my saved messages on my computer at home. I'll look tonight.
Old Apr 21, 2003 | 07:25 PM
delio's Avatar
The official answer, at least on the 4th gens... 4Ft.
Old Apr 21, 2003 | 08:15 PM
DanNY's Avatar
Ad·min·is·tra·tor
cut the line to size. take the lower sleeve from the AN fitting and slide it on the line 1st..then jam the rest of the fitting to the end of the hose. slide the coupling up and screw it on until it's tight.
hard line is better and more reliable only if it's done correctly.
Old Apr 21, 2003 | 10:47 PM
Y2KevSE's Avatar
Don't forget to tape up the frizzy end or your fingers/hands will get pricked.
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
