Grinding noise under the hood...
When I put my car in reverse and step on the gas I get a grinding noise from under the hood on the Pass side. I remember reading a while ago that the strut bar causes something to grind against it in reverse. But I checked and everything looks like it clears the bar pretty good. Anyone having this problem?
Nice
Nice
Re: Grinding noise under the hood...
Nice
Nice
hope this helps.
Maybe you shouldn't be tromping the gas in reverse!?
j/k!
The motor torques the opposite way in reverse so its probably your strut bar.. Try putting some 1/2" washers on the bar to change the clearance... Don't go to high or you hit the hood of course...
j/k!The motor torques the opposite way in reverse so its probably your strut bar.. Try putting some 1/2" washers on the bar to change the clearance... Don't go to high or you hit the hood of course...
Originally posted by krmaxima
u put 3 washer under each bolt how in hell did u clear the hood????? i have only one washer and it still makes the noise but it touches the hood???? barely
