maf adaptor
Old Apr 22, 2003 | 01:20 PM
kingrye's Avatar
maf adaptor
i bought an intake adaptor off ebay and they sent me a square maf addaptor and the vg is rectangular so i turned it so that i could get 2 screws in will this be alll right i tightened them really tight.
Old Apr 22, 2003 | 01:25 PM
cneary812's Avatar
Re: maf adaptor
Drill out the other 2 holes so you can get all 4 lined up. It is most likely just aluminum.
Old Apr 22, 2003 | 01:38 PM
kingrye's Avatar
the metal is not wide enough so there is nothing to drill
Old Apr 22, 2003 | 01:43 PM
MAXMAN91's Avatar
yeah i got one of those too. i could only get two holes to line up also. so it has worked fine for about 6 months no prolem
charlie
Old Apr 22, 2003 | 02:30 PM
Nissan-R's Avatar
Same here. Just tighten the screws really good and you should be all set.
Old Apr 22, 2003 | 11:48 PM
rymo926's Avatar
me too but i'm sure it's leaking air in, maybe try a home made gasket.
Old Apr 24, 2003 | 08:13 AM
cneary812's Avatar
Just remember that there are 4 screws in there for a reason. 2 may seem to work fine but you could be sucking in dirt from that opening and over time... you can fill the rest...
Old Apr 24, 2003 | 08:30 AM
nismo1989's Avatar
You should be able to turn the adapter and drill out new holes for it to fit. You got one for a 4 cyl. engine. They don't specify because they're dumb, but that's what happened. I've seen it several times.
Old Apr 26, 2003 | 10:42 PM
gottriceguy's Avatar
Same thing happened here. All I did was turn the adapter diagnally and screwed them into the bottom left and upper right hole. It was perfect. I've checked it every other week for the past couple o'months and its still there. Never had to tighten once.
Old Apr 26, 2003 | 11:13 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
ummmm yeah...so much for proper sealing and preventing the MAF from being damaged.
Old Apr 27, 2003 | 03:59 PM
MAXMAN91's Avatar
so what can i do addae to fix it.b/c i only have 2 holes screwed in. do i need to make 2 more holes. or can i buy a better one somewhere else?
Old Apr 27, 2003 | 04:40 PM
DA-MAX's Avatar
my advice would be to get one from Cattman or lightningmotorsports.com...they will cost about $25-30, but they are the REAL Nissan MAF adapters!!
I'd just get it from Cattman, but if you go with Lightning MP, I think the "type M" is what you want. most of those Ebay Nissan MAF adapters are for the 4-cyl models which I think have a different bolt pattern("type N").
Old Apr 27, 2003 | 09:10 PM
Because you wrote that, I went back and checked my MAF. Its ****ing flawless. No cracks, no opennings. Damaged you say....I've been using it this way for months and its still good. You crack on me when theirs some other guyz that has it screwed in on one side! So **** off. ****ing loser.
Old Apr 27, 2003 | 09:15 PM
AscendantMax's Avatar
whoa big guy...he didn't mean anything bad. IF it wasn't sealed right, dust and other crap can get in and possibly damage your MAF and the insides of your engine. don't want that now do we? He just wanna point that out to ya. no hard feelins
Old Apr 27, 2003 | 09:33 PM
I'm sick of his ****. I know about the dangers. My methods are different, but it works better than the other alternatives. I'm not dumb enough to risk exposing one side of my adapter to dust (no offense to those who have). Da-Max needs to stop picking on me cause if I ever meet him in person.
Old Apr 27, 2003 | 09:50 PM
DA-MAX's Avatar
riiiiight..... I'm friggin terrified look, look, my hhhhaannnds aaree sshakking sssooo mmmuch IIII caaannn bbbarellly tttyppe....save it buddy.
Old Apr 27, 2003 | 10:03 PM
If only you knew...If only you knew who I was and what I would do.
Old Apr 27, 2003 | 10:28 PM
just curious...how old are you?
Old Apr 27, 2003 | 10:31 PM
KLoWnPR109's Avatar
You gonna beat someone up because they are trying to save your MAF? Kick his *** seabass
Old Apr 27, 2003 | 10:35 PM
i see a lock coming up...
Old Apr 27, 2003 | 10:41 PM
DA-MAX's Avatar
you watch too many gangster movies
Old Apr 28, 2003 | 05:11 AM
cneary812's Avatar
FYI as you learn the way this site works you will understand that no one here means is here to bash you. They may say things that if you take it the wrong way could seem harsh but they are not. There is alot of experience with trial and error here. It doesn't necessary mean that your way is wrong, but different than the norm, if it works, more power to you but be prepared to be picked on a bit, especially when you have a newbie rating.
Just the way of the Forrum dude
No hard feelings.
Old Apr 28, 2003 | 08:48 AM
surfermax92's Avatar
Now that's the way to respond. You tell him...
TallTom
57
Oct 14, 2025 05:16 PM
9aj9
Apr 5, 2020 12:11 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
magiconthetire
Oct 26, 2015 09:03 PM
ballerchris510
Sep 10, 2015 09:35 PM
