Brake light keeps coming on?
Old Apr 23, 2003 | 09:07 AM
JMaster's Avatar
This only happens in the morning, but every morning, my emergency brake light keeps turning on. I drive stick, and it's not like I ever drive with my brake on lol, but why would this happen?
Old Apr 23, 2003 | 09:08 AM
t56gen3's Avatar
Check the fluid level in your brake reservior. Low fluid level can trip the light too.
Old Apr 23, 2003 | 09:14 AM
Maxman2000's Avatar
This was posted a while ago too. Same problem.
Old Apr 23, 2003 | 12:30 PM
jmh8's Avatar
Your brake fluid is low. That is all it is. I had the same problem.
Old Apr 23, 2003 | 12:33 PM
njmaxseltd's Avatar
Low brake fluid is an indication that your pads are worn down. Have them checked and replaced if needed.
The system is designed so that as the pad wares down, the fluid level drops accordingly. When the fluid is low enough to trip the light, it usually means you need or are coming close to needing brake pads.
Old Apr 23, 2003 | 05:49 PM
JMaster's Avatar
Ok cool, thanks. I need new rotors anyway, so might as well kill 2 birds with 1 stone.
Old Apr 23, 2003 | 07:20 PM
bert's Avatar
However, if you have ever had fluid added watch out.
After a brake job, mecanics will often add fluid to the reservoir to top it up, even though you only did the front or the rear.
The problem comes when they push the pistons back in. The reservoir may overflow. The biggest problem is that brake fluid is very corrosive. You don't want this anywhere near a finished surface, like paint.
A good shop will pop the top of the reservoir and suck fluid out before pusing the pistons in.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
