Brake Judder
Old Apr 26, 2003 | 10:44 AM
David W.'s Avatar
Brake Judder
I had the notorious brake trouble with brake judder after only 20k so instead of going through the endless cycle of re-surfacing, I opted to replace the front rotors with Stillen drilled rotors and metal matrix pads. The brakes work great now and there is no judder, but there is a noticeable whirring noice when stopping. Is this normal to expierence with drilled rotors? What is the maintenence like on the drilled rotors? Can they be resurfaced like stock rotors if needed? Any info will help.
Old Apr 26, 2003 | 02:09 PM
jnovember's Avatar
Re: Brake Judder
I also have the same rotors/pads. Yes, there is some whirring noise when braking. BTW.... Brake Judder is back after 30+k. As someone who on other cars routinely got 100+k out of a set of rotors/pads, not sure what I am going to do next.
Old Apr 28, 2003 | 01:25 PM
David W.'s Avatar
Re: Re: Brake Judder
did you do the rear rotors too?
Old Apr 28, 2003 | 04:17 PM
2MuchMAX4U's Avatar
Re: Re: Re: Brake Judder
Check out my old post on this...Warped Rotors, I've had a nightmare with brakes, I've learned alot about cars through!
I have only had problems with my front w/60K my rears are still stock!
I will be resurfacing my XDrilled (2nd Cut) and my stock rear rotors (1st cut), soon as well as installing Raybestos Ceramic pads both front and rear.
If you read my post I'm wondering if it's something else besides driving style/ Nissan OEM Rotors and Pads, etc.....Calipers?
Good luck
Robert
Old Apr 28, 2003 | 05:20 PM
Max_5gen's Avatar
Re: Re: Re: Re: Brake Judder
Good luck
Robert
I already suggested that we need a poll to see what aftermarket pads + stock rotors work well on Max. From my own experience and posts here I got an impression that we have two brands for now: Raybestos Ceramic Quiet Stop and Porterfield R4S. Cutting rotors has been proven to be useless. I've already put 35-40k miles (it was too many miles ago to remember exactly) on my last set of stock rotors using R4S without that problem coming back. I haven't change my driving habbits, drive agressively, have open summer wheels and don't care about rotors temperature when I'm going to car wash. I've been doing so for two years. I do use torgue wrench, mostly out of habbit since it didn't prevent that judder from coming back the last two times when I had stock pads. Speaking of rotors temperature mine get very hot since I'm using T1S tires in summer and they significanly shorten stopping distance in comare with crappy stock A05. IMHO set of good pads well worth the hassle of cutting rotors twice a year. I also service brakes myself making sure that sliding pins actually slide .
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
